Simplistic Mosfet HV Shunt (SSHV for Phono and Tube Pre)
Design by Salas, Make PCb and kit by quanghao
Hi all!
SSHV shunt regulator is a great hight voltage Shunt supply for Tube Pre amlifiler and phono.
So many people have no free time, like me make this kit, so I try to complete it for you!
How interested would you sign up, I will try the first 10, and will offer a fair price for a kit
All information you can see this link:
http://www.diyaudio.com/forums/power-supplies/134801-simplistic-mosfet-hv-shunt-regs.html
And:
http://www.diyaudio.com/forums/powe...stic-mosfet-hv-shunt-regs-97.html#post2084348
I use SSHV for Phono ASH ( Phono D3a design by Andrea):
http://www.diyaudio.com/forums/quan...i-end-phono-preamplifier-andrea-ciuffoli.html
And Group by:
http://www.diyaudio.com/forums/quan...hv-shunt-simpler-simplistic-design-salas.html
Hi all!
And:
And Group by:
Here is the original schematic and circuit diagram for the kit SSHV
Quang Hao,
Do you mean you will offer a completed and tested kit? Or just the components needed to build the SSHV? How about just the components without the PCB?
Quang Hao,
I have 2 option you can choice
1. The completed and tested kit
2. All comment + PCB ( I can help you all comments without PCB, if you like)
thanks
Quang Hao,
Since I bought 2 x SSHV pcb from you recently, can you let me know how much will 2 sets of complete components will cost?
Quang Hao,
i will reply you later!
Quanghao
Hi, I am new on this site, I wish to build a Phono stage with the power supply you mention in this thread, can I obtain both the SSHV and the Phono Pre-amp in Kit form with all the parts supplied.
Jezza
Jezza
Jezza
Yes! you can Have it, if you like it!
You see in this link:
Kit SSHV for Phono and Tube Pre - Quanghao.com
Here is the measure SSHV
Those are not measurements but LT Spice simulations you probably found in my thread.
I have already the PCBs from you. What I am interested is,
if you could provide me whit other parts including kiwame resistors??? If so,
please tell me how much would that cost for two boards.
Hi you can choice anything in this web:
The Hificollective shop
Part Connexion 1$05 USD are cheap than HIFI Collective 1$26 both 2W:
KIWAME - 2 Watt Carbon Film Resistors
Hi Quang Hao,
I received my Kit the other day, would like to Say Thank-you, the quality is outstanding, I have one question so far the Caps C6 and C18, I noticed that they are not used on your board are they needed or is there some special circumstance where they are required, I do have them in my parts so can use them if they will improve circuit.
Regards Jezza
Regards Jezza
Hi Quang Hao,
Regards Jezza
Hi! it is good!
it no need! you do not worry about it! If you still need it, i can sen it to you!
you test it??
- More Vendors...
- Quanghao Audio Design
- Kit SSHV for Phono and Tube Pre (Simplistic Mosfet HV Shunt )
