This hand built tester is part of my arsenal now. I like the analog meter.
Did any of you ever build something like this?
It has (high ohms, injector, low ohms, 10,000 ohm voltage divider, etc.) switches and dials.
I've only figured out how to measure a 1.5 volt battery so far. It would be nice if I could do a little more than simple volt measurements.
I'd really like to be able to use the milliamps test feature.
Any help will be appreciated.
