Any of you guys use Kilz interior oil base spray sealer-primer on MDF? If so, how were the results.
I'm planning on sealing all cut edges with a 50/50 mix of Elmers glue and water, the trying several coats of the Kilz. After that, I want to use lacquer (several coats) on top.
If this plan is all screwy, please let me know, I'm not much of a paint guru.
Thanks, Tony
Thanks, Tony
Water and MDF are not good companions. You may do more harm than good by trying to seal cut edges this way.
I suppose that if you've already got Kilz on hand, paid for, that's a strong argument in its favor, but it wouldn't be my first choice. I'm not sure how well lacquer will adhere to it.
Grey
Grey
this may be the near most place for you
maybe;
central auto parts
801 e central ave
commanche tx
76442
(325) 356-3925
i cant seem to link to duponts
web site,they have a jobber look up
seen this?
http://community.webshots.com/photo/55871145/241158826lMhyGi
maybe;
central auto parts
801 e central ave
commanche tx
76442
(325) 356-3925
seen this?
just been building some furniture out of MDF for my new studio
sealed it first with a PVA/water mix and rubbed it down with a 600 grit then a 1200 grit paper
then sprayed it with a cellulose primer and top coat rubbed in between with 1200 grit
it's come out lovely and i'm really impressed
i figured it would be good practice for when i get some cabs knocked up and reckon with a bit of patience and several layers of laquer a piano finish could be achieved quite easily
i will say one thing though your final finish when spraying is entirely dependant on how good the original surface is ANY imperfections will show
- Kilz
