Killing HLLY TAMP 20
I appreciate your reply and the link you sent. Money isn't an issue, but I was under the impression that running the amplifier at only 12V was handicapping the output. Is this not the case? Is there a formula that calculate the output for a given voltage?
Thanks!
I run on batteries quite frequently and can hear no difference from fully charged to just before the amp goes choppy from low voltage.
I tend to run almost anything at half capability. If the 2020 doesn't cut it at 12v I would move up to a 2050.
