kicker zx700.5 Protection mode please help
Hi, I have bench tested the amp I get a red light for protection I have check mosfets all look good no shorts no visually damaged components I believe it could be todo with the diodes in the protection circuit.
Any help will be appreciated
I have tested the diodes all are reading correctly
Yeah connected the input to the sub channel xover off on both channels no other switches. I think there is ground issue as only getting continuity on rca should and amp 1 channel both sub and amp 2 have only got continuity with amp channel one rca
Start a new post with good quality pictures of board. Take one picture of the whole board w/o the input board. Take two pictures splitting the board in half, power supply and output stages. One more of the input board. A smart phone, good lighting and backdrop will yield good results. Give as much detail as possible.
