ok thank you im hoping thats the problem. im guessing the guy i bought it from on ebay tried to fix it himself by replacing the whole line with the irf9640's and didnt notice that two were irf640's. i will order some of those and see if that fixes it and once again thank you so much for your help i really appreciate it.
you welcome, just remember to buy original parts and will have it working for long time without issues.
so should i just buy new irf9640'S and irf640'S from the digikey site or do you think the 4 i took out are good?
If is possible buy it all 4 IRF9640PBF and 2 IRF640PBF but if you wanna sabe some bucks just put back the original ones. Try to not use the last ones you bought. Those look suspicious.
Sent from my GT-I9300 using Tapatalk
ok thanks i will give it a try and yeah i did little research before buying just figured they were all the same but these are definitely not giving me the same readings as the ones i took out. but thanks again i will let you know how it goes when the parts get in unless i can find them locally somewhere reasonable which i doubt in va lol
the IRF640's tend to fail more often then the IRF9640's. The 640's should read 50kohm across the outside leads, with the mosfets in or out of circuit.The 9640's should read 50kohm also outside to outside.Be sure that the gate resistors(they will be attached to the first pin on the left, looking from the top with the power terminals on the right) read the correct value. I believe the value is 10 ohms(The value is printed on the top of resistor) If the gate resistor is out of value it will cause the mosfet to blow.
I am getting 50 across all outside leads. if the gate resistors values were off would i still get this reading? and there are two types one says [104] and the other [100]. i took one of each off of the circuit to test and the [100] read 10ohms and the [104] read 100ohms. thanks
check the values here : SMD resistor code calculatorI am getting 50 across all outside leads. if the gate resistors values were off would i still get this reading? and there are two types one says [104] and the other [100]. i took one of each off of the circuit to test and the [100] read 10ohms and the [104] read 100ohms. thanks
on board measures could be lower than resistor says because the other components in the same layout. for precise measurement have to carefully remove it from board. gate resistors are critical. if one is open or in higher value state will blown the mosfets again.
the 104 is 100kohm, which is why the ohmmeter is reading approx 50 Kohm on outside leads. 2 100kohm in parallel essentially. your measurements look good.
when I say 50kohm its approximate, and will be lower maybe 49kohm. the gate resistors (100) should all read between 9 and 11 ohms, depending on the accuracy of meter and resistor tolerance.
ok thanks id like to replace one of them for sure if not all of them and im unsure as to what size they are? i have a what looks to be a size smaller [104] can i use that or will it mess it up?will it make a difference if i just order the same amount?can they be a size bigger? thanks again
the size of the resistors are 0805, I would not use anything bigger or smaller and the 0805 are not hard to get through mouser or digikey.the values are 10kohm 10% and 10 ohm 10%.
ok are these the correct ones?
RC0805FR-07100KL
RC0805FR-0710KL
sorry it wont let me post the link to digi key
RC0805FR-07100KL
RC0805FR-0710KL
RC0805FR-07100KL will work for the 100K ohm, but the 0710KL is a 10K ohm resistor.The following part number will work for the 10 ohm: RC0805FR-0710RL.
i just went ahead and ordered all new irf9640's and all the resistors and everything should be in by friday. thanks again for all the help everyone i really appreciate your time.
ok so i got all the parts in today. i ended up replacing two 100k and one 10ohm smd resistors. all four irf9640's and two irf640's. it works and powers on and everything and seems to work fine. my only concern is a really faint high pitched noise coming from inside the amp not sure if its a big deal or not i could barely hear it and it appears to only come from inside the amp. i was thinking it was from not having enough power or something because i used a old computer power supply.
thanks for all your help im happy to make it this far
The high pitched noise is common for this amp. It's coming from the power transformer.If you gentle push the winding's away from the core you will noticed a change in pitch and maybe at a diminished level. You can apply a thin layer of clear silicon around the top of transformer if it is an issue,otherwise you are good to go. Good Job!
thanks again i couldnt of fixed it without all of the help from you guys! and that faint noise doesnt bother me one bit just wanted to make sure...And now to fix a older rockford fosgate 4 channel amp with no noticeable damage. it looks like quite the task compared to the d series lol
- General Interest
- Car Audio
- kicker zx400.1 issues
