Kicker zx1000.1
Hi all
The above mentioned amp is dead. All fets looking good. The amp does not come on at all. Pin16 of 494 has around 11v.
594 is having oscillations.
Is it safer to remove the driver board away before I force to to power it on by removing d7? Because I cannot reach up to get voltages with driver board on it. Also will it be safer to do so that I won't blow anything bad?
Checked all mosfets and all looks good no shorts.
Correction:
Measure the DC voltages around U3 referenced to the (-) speaker terminal.
Always use the following format when posting DC voltages around an IC.
U3
1-
2-
3-
4-
etc..
Also, post DC voltages for both U1 & U2, this time using the power ground terminal.
