Are you sure that you had 0v on the end of R110 that is not connected to pin 3 of U102?
P Perry Babin Member Joined 2003 bcae1.com 2011-10-06 2:29 am #61 2011-10-06 2:29 am #61 Are you sure that you had 0v on the end of R110 that is not connected to pin 3 of U102? ••• More options Share T timwebb Member Joined 2010 2011-10-06 2:39 am #62 2011-10-06 2:39 am #62 rechecked and its 0v ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-06 12:40 pm #63 2011-10-06 12:40 pm #63 On U102, if you solder a jumper between pin 2 and pin 6, does the voltage on pin 3 go to 0v? ••• More options Share T timwebb Member Joined 2010 2011-10-06 9:31 pm #64 2011-10-06 9:31 pm #64 yes its 0v. ••• More options Share T timwebb Member Joined 2010 2011-10-07 7:35 pm #65 2011-10-07 7:35 pm #65 Defective ic? ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-07 8:09 pm #66 2011-10-07 8:09 pm #66 With the jumper in place, what is the DC voltage on the speaker terminals for that channel? ••• More options Share T timwebb Member Joined 2010 2011-10-08 6:20 am #67 2011-10-08 6:20 am #67 -28.2 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-08 4:34 pm #68 2011-10-08 4:34 pm #68 Do you have any module plugged into this amp? ••• More options Share T timwebb Member Joined 2010 2011-10-08 5:50 pm #69 2011-10-08 5:50 pm #69 No ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-08 7:05 pm #70 2011-10-08 7:05 pm #70 Remove Q109 and Q111. Does the DC on the output drop to near 0v? ••• More options Share T timwebb Member Joined 2010 2011-10-08 10:01 pm #71 2011-10-08 10:01 pm #71 Yes I have 0v now ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-09 12:27 am #72 2011-10-09 12:27 am #72 On the two TL431s in this channel, what is the DC voltage with the black probe on pin 2 and the red probe on pin 1? Don't slip and short the pins. ••• More options Share T timwebb Member Joined 2010 2011-10-09 8:36 pm #73 2011-10-09 8:36 pm #73 +2.51v on both ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-09 8:39 pm #74 2011-10-09 8:39 pm #74 Check the two drivers that you removed. Do both have two good junctions? Is there any reverse leakage or leakage from collector to emitter? ••• More options Share T timwebb Member Joined 2010 2011-10-09 10:21 pm #75 2011-10-09 10:21 pm #75 both test good. i get no readings across the pins. i would like to replace them any way. Last edited: 2011-10-09 10:48 pm ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-10 1:19 am #76 2011-10-10 1:19 am #76 Remove the jumper on the TL071 and post the voltage on pins 2, 3 and 6. Leave those drivers out of the circuit. ••• More options Share T timwebb Member Joined 2010 2011-10-10 2:02 am #77 2011-10-10 2:02 am #77 2- -15.56 3- -13.5 6- 13.8 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-10 2:08 am #78 2011-10-10 2:08 am #78 In the future, don't use a hyphen as a separator. Post the DC voltage on all 8 pins of U101 near the RCA jacks. ••• More options Share T timwebb Member Joined 2010 2011-10-10 2:20 am #79 2011-10-10 2:20 am #79 1. -13.7 2. -13.6 3. -13.5 4. -15.1 5. -13.7 6. -13.5 7. .-13.6 8. 14.8 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-10-10 2:25 am #80 2011-10-10 2:25 am #80 Did you repair the open ground in this area that was discussed earlier? If not, find it and repair the open trace. ••• More options Share Prev 1 2 3 4 5 Next First Prev 4 of 5 Go to page Go Next Last Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home General Interest Car Audio kicker xs100 Top Bottom
