Kicker DX1000.1 power supply help.
Need help with remaking connections around q4 it burned some trace and I don't have one to compair.
The ZXTC2045E6(Link below) pin out is as follows:
Using the conventional pinout starting with the dot as Pin 1 and around counterclokwise ending with Pin 6.
1: C1
2: B1
3: C2
4: E2
5: B2
6: E1
Based on that, Pin 4: E2 and Pin 5: B2 have damaged traces.
B2 is tied to B1 and in turn tied to Pin 6 of IC20-UC3843.
E2 is tied to R32,R33-1RΩ or R11,R12-33RΩ.I can't tell with just a schematic. Whatever E1 is tied too, then E2 will be the opposite.
https://www.diodes.com/assets/Datasheets/ZXTC2045E6.pdf
Ok so after repairing the trace a few places
I got it to produce some drive.
What ps mosfets does this amplifier use?
And output transistors?
