Q02 has its collector connected to ground so thats a MMBTA56
Q11 has its base connected to ground Q05 appears to be the same as Q02 ..
Q05 is marked ASG any ideas on a part number for it ?
Theese are the power supply drivers Q11 has its base connected to Leg 3 of the 3205's
Q02 has its collector connected to leg 3 of the 3205
That transistor is out of circuit since it was defective and badly burned..
From the collector (3rd leg) to the 3205's 3rd leg i get 46.7K ohms
Q05 has its base connected to the 3rd leg of the 3205 also and i get the same readings off that transistor as well and its marked ASG
So im assuming Q11 and Q05 are both the same..
No ..
If thats the right order then Q11's collector would go to ground
Q02's emitter would go to ground and leg3 of the 3205
I looked at the board at Q05 and Q11 should be the same Marked ASG
Q02 and Q26 are the same marked ALG
So the MMBTA56's should work in both locations correct ?
- General Interest
- Car Audio
- Kicker 750.1
