Kicker 1500.1
I got one of theese amps in for repair and i need to order some parts for this thing.
This amp was taken apart by someone else and alot is missing off the board.
I missing the fets, outputs, power supply drivers, gate resistors, the rectifiers have broken legs, Class D board is fried, and ect..
So i need to order some parts but need help with a few of them..
Power supply fets are IRF3205'S Correct?
Gate resistors are 100 ohms 1210 package??
Missing the power supply drivers : Q24 Q25 Q26 Q27 anybody know what part numbers they are??
Outputs are IXTQ36N30P correct??
And anyone find a good source for the rectifiers : MOSPEC F30D40D ??
**** Yes
**** Yes
**** The originals are 2SD667s and 2SB647s but different transistors were recommended:
http://www.diyaudio.com/forums/car-audio/161008-kicker-1500-1-a-5.html#post2100365
**** Yes
****No
Ok got parts in for this amp..
The orginal power supply drivers im replacing with MJE171 and MJE182G..
Will the MJE182G work as a good replacement for the MJE181 since i couldnt find anyone who had them..
Also is it the MJE171 or MJE182g middle pin connect to ground??
I can't tell on the photos of the 1500. If it's the same as the 1000, it's a TIP42C.
