Kenwood LSK-300 cone Tweeters
Hi all,
I have vintage LSK-300 Kenwood stereo speakers.
The 60mm tweeter has been damaged while cleaning (!).
Please help me by providing the information for replacement for this TWEETER:
1. Paper cone Type
2. 60mm tweeter (I dont know what this means)
3. impedence 8ohm
Thanks in advance.
The pictures of the tweeter are attached along with this email.
Thank you, @duncan2.
>> There are plenty of 8 ohm paper cone tweeters in the market but I cant find the same type/size of your original which---I take it ? you would want .
Could you please let me know what would be frequency response range for the tweeter shown above ?
Also, how much watts should it support?
Thank you !
I can only find the MK11 version which shows a FR of 15KHz -20KHz ,
the mid-range going from 3300KHz - 15KHz .
The crossover in a loudspeaker design determines the frequency of each loudspeaker unit it outputs.
Tweeters don't use many watts .
P.S. The damage appears to be a hole or tear in the paper cone near the metal dustcap.
This would be repairable by covering it with a couple of layers of tissue paper wetted with diluted PVC adhesive.
The sound after the repair should effectively be indistinguishable from the sound before the damage occurred.
