Kenwood KAC848 amp
I have a Kenwood KAC848 amp with the rail voltage fluctuating from about 28v to 33v. The 494 chip has many pins also going up and down. I will list the pins below. Please let me know where to start with this.
thanks Jeff
494 pins
1. 2.5 - 2.7v
2. .8 - 2.5v
3. 4.8 - 1.8v
4. .63
5. 1.69
6. 3.7
7. 0
8. 14
9. 0 - 4v
10. 0 - 3.7v
11. 14
12. 14
13. 5
14. 5
15. 5
16 0
Have you checked the output transistors to determine if any were shorted?
For the following, the meter will be set to DC volts and the black meter probe will be on one of the non-bridging speaker terminals.
Do you have positive voltage on the center leg of D11 and negative voltage on the center leg of D12?
Do you have either positive or negative rail voltage on the center leg of each of the output transistors?
Do you have both positive AND negative voltage on the power supply pins of each of the op-amps?
The outputs don't seem to be shorted. D11 has positive voltage going from 22v to 33v and D12 has negative voltage going from -22v to -33v.
The 2SA1908's have negative rail going from -22 to -33v and the 2sc5100's have positive rail going from +22v to +33v.
I connected a signal and the amp will turn on and work good for about five minutes. then turn off for about ten minutes. the readings are from when it turns off. when the amp is on the rail voltage becomes steady.
Perry, thank you so much. I checked the board for a broken solder joint and found the transister between two of the outputs. I resolder it and other's that looked bad and now the amp is working great. Thank your help. Jeff
