Kenwood KAC-7005PS Problem
I don't know where you're located so I can't recommend electronics distributors.
The IRFB31N20D is obsolete. Any you find may be counterfeit. The IRF640 or IRF640N may be a suitable replacement. You must replace both the defective FET and the one that was parallel with it.
Does the sub channel now produce audio?
Ok. I didn't play music through it because i had things not fully clamped down. Should I?
I would be buying offline usually I use Mouser.
I connected everything and iam getting a pulsing coming out of the sub channel even if no music is being played.
Iam I looking just by the bad FET that I removed? I don't see anything else besides the resistors I checked.
