Kenwood KA-8011
Hello guys,
I would like to ask something about my ka-8011 which is same as kenwood ka-801. I don't have the amplifier for long time and it is working lets say normally.
It was surprise for me when I opened bottom cover and saw this.. Path to Q1 collector burnt. What can cause this and how it is possible that it can still working with burnt path ?
Thanks a lot
I would strongly suspect that you have a faulty Q1 and the amplifier has opened circuited the track th e amp is using Q5 only I would first check Q1 for shorts between collector and emitter if this measures ok I would then link the bad track out if faulty replace both Q1 and Q5 with a matched pair
hi, so I fixed burnt link, also had to change bias trim pots and some zener diodes, some capacitors 😀 I had trouble with high bias, but now is stable and I'm able to set it to 18mv.
