Hi guys,
I have this bench DMM, bought 2 years ago. Since last week the highest sensitivity ranges readings are out of whack with values that start from 0.2V and go to 1V with or without probes attached. If i set the range immediately greater (200m), everything is fine. Therefore I cannot do measurements smaller than 0.1 mV, which is OK for DC offsets, but not for measuring the ripple of a PSU.
This is ******* me off very much.
I checked the manual, which says only to zero (with probes shorted I read all 0 or almost that, so it is NOT a DC offset issue), and be careful of EMC. I dont believe I have halv volt of DC floating in the air... but If i get closer or farther from the multimeter (or the probes, if attached) the voltage fluctuates a good .3-.4V (!)
The DMM is mains-powered, and I don't have the battery-pack installed (but I plan to get one if i find reasonably cheap).
I googled but didnt find any help. So thanks in advance to anyone giving me some clue.
