PSW 2000 schematic needed
Hi everyone!
Just got in touch with this forum!
I have a PSW2000 sub that doesn't work.
I got it repaired but all it did was popping and buzzing...
It went to repair again and it popped as I turned it on and died.
It's still in repair now but I'm willing to take a look myself so can anyone send me a PSW 2000 schematic?
My mail is rumimeso@gmail.com
Thanks in advance!
Hi everyone!
Thanks in advance!
A copy of the service manual is freely available on my site here:
http://www.slickpepper.org.uk/kef-psw2000-service-manual-including-schematic
Dan
Dan
KEF PSW2000 driver
Hi everybody. Do have you got any technical data about woofer driver installed in KEF2000? I have service manual kindly provided by KEF but it says nothing about the type or the main params like Qts or Vas. I need them to choose the right replacement for my burned driver. I will appreciate any advice with this regard.
psw 2000
hello
I would like the scematics for the kef PSW 2000.
please send to jvast@hotmail.com
thanks
hello
thanks
and is this the same relay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300256191450
needmorstuff said:i have a psw2010 - the relay is constantly "chattering" is this a simple case of replacing the relay or is it indicative of bigger issues?
needmorestuff - try replacing cap C52 - this does the smoothing for the relay supply. If it's gone then you will get a 50Hz relay chatter. I used a 100uF, 100v unit as it was handy. Anything in that region should be fine.
Dan
Roar Malmin said:Guys, if you read post 15, you will find all the information you need to fix these subs. Do them all.
Roar
Agreed - that post is most helpful!
Thanks,
Dan
Re: KEF PSW2000 Scematic Diagram
see post #29 and try a bit harder to find what you need before asking as it just bloats the thread.
Good luck,
Dan
HBX said:Anyone who can help me with a KEF PSW2000 schematic diagram. My subwoofer died and would love to get working again.
Thanks,
Hans
Good luck,
Dan
- Subwoofers
- Kef PSW2000 Sub schematic required
