KEF LS60 like speaker build
Hi.We want to build a speaker like KEF LS60 with my friend. It is very WAF speaker and i liked the design a lot too(wife fall in love 🙂 .Altough i built a similar design and sound is very very good (i attached in picture ) i want to build like KEF because it looks better.
Which woofers can we use ? It should not be same as KEF. Maybe we can use bigger woofers to get better bass too. (but i want to make back to back woofers but i do not know which woofer will be good) Please advise.
With ref., to your design questions:
1. Is the 1 or 2 woofers mounted on each side?
2. Is the woofer cabinet ported or sealed?
Some details are appreciated.
umut1001 asked about SPL, (I don't want to take that literally until I'm sure that's what was meant, however..) of course you can get +6dB summation with one speaker in each corner of the room.. 1/4 wavelength doesn't come into it.
You won't have me confused this time Allen! 😉
For a couple of drivers: both drivers if located within 1/4 wavelength are considered as 1 source of emmission ( there is acoustic coupling at work, you can stretch the ratio to 1/3rd wl). If they are located back to back or on the same face doesn't matter as long as Ka is low enough ( below 1, or iow as long as the driver doesn't operate in a range where it start to be directive).
Spl will growth from the surface doubling ( +3db) and if connected electrically in // (another +3db eg: from 8r to 4r). If series connected there is no 'electrical gain', so spl= the same for one driver but the series compund driver will accept more power overall (than a single unit).
If you use 4 woofers you'll probably need serial/paralell combination ( 2 group of series connected drivers then paraleled). Spl capability will gain up to 9db iirc).
