Kef iQ9 almost blow my to mcintosh amps when bi amp!!!!
Hey guys,
Today I almost went crazy when I'be bi amp my kef iq9 speakers (which is indicated in the manual) and it caused my two mcintosh amps to go on safe mode!!!!
Very strangely by disassembling the speaker I find a resister making a shunt between the two negative connectors of each speaker!!!!!! This is not ok, what is Kef doing?
If you're still driving the passive crossover, I wouldn't bother with bi-amping. There's nothing to be gained, since you're still driving capacitors and inductors, and still feeding your amplifiers with full-range signal.
Do it properly, bypass the Kef crossover, add a DCX2496, miniDSP, whatever, and set off by recreating what the original crossover did.
Chris
Well, even with full-range, biamping can yield at least small benefits. For instance, the high pass section won't have the bass current, so the amplifier's power supply will act "stiffer" than otherwise.
The type of problem Sander's Mag tech amps solve. 🙂
No substitute for active crossovers though. 🙂
Best,
Erik
