KEF 105.3 crossover
I have a schematic One of the inductors has a value of .07mh. Is that a typo. Or are there inductors of the low value?
To spice up the discussion, post #17 in the thread below has the KEF maintenance document attached.
The schematic in the document shows the inductor in question (L34) as having an inductance of 0.007 mH!
Which is also the value annotated in the diagram of the physical crossover board.
Reactions: Cwess
Full schematic attached.
Thank you, now it is clear - that RLC trap is in the tweeter filter branch and it levels a peak in the tweeter frequency response.
If the inductor is 0.07mH, than the maximum attenuation is at 4.254 Hz.
If the inductor is 0.007mH, than the maximum attenuation is at 13.451 Hz.
Based on this numbers, it is inconclusive - both frequencies are logical for a tweeter. But I think 13.451 Hz is the most probable, so the inductor value should be 0.007mH.
Reactions: Galu and Cwess
