Karlsonator for Prosound 8" L74AW and planar tweeters
Hello everyone, got a pair of these prosound drivers for like 6e the pair and thought I'd slam them in a karlsonator with some planar tweeters sitting on top (no k tube as the shape of the tweet is rectangular). I cannot find proper TS parameters (hence this design, more flex with those poorly documented drivers). Now my problem is obvious. Which size of box should i go for? Anyone can find the tsp? And all kind of help appreciated.
Thank you team
depending upon fs, if qts is moderately high then the stock Karlsonator8 may work as its tuned very low at ~41Hz. If the motor is strong and loud midrange-lower treble, then a Karlson K12 may work. In between those could be XRK971's
XKi bandpass type. Even if rolloff starts around 74Hz with a K12, it can rival some horn in punch and articulation. A rising on-axis response can be helpful as K traditional and Karlsonator variant tilt the driver back.
Is it "this" ?
attachment.php
And I'd like to build the karlsonator variant as it's for my living room and daily use. Karlson model will be for the bigger boys, as tops sitting on a bin each, maybe as mid tops and have horns on high tops but let's not get sidetracked. �� Oh and I also would have a passive xover 2 ways cutting at 3khz
