Karlson -XKi style "KUBE 12" for Kappa 12A
I wanted to see what could be done in a little box.
Here's the size comparisons to Greg b's "Karlsonator 12" and Karlson's "L12" cabinets -
(there's almost no damping material in the box other than a few melamine sponges on one side of its floor)
KARLSONATOR 12 bulk = 5.333 CF / 151.05 liters. Fb ~37Hz
KARLSON "K12" = 3.265 CF / 92.48 liters. Fb ~63Hz
KUBE 12 = 2.18 CF / 61.77 liters. Fb ~59Hz
So KUBE 12 is 2/3 the size of a K12 amd 2/5 the size of GegB's Karlsonator 12.
As built by John Lapaire the dimensions are 15" W x 15" D x 16.5" H using 1/2" plywood for the sides/top-bottom and baffle, and 3/4"plywood for the back panel and aperture plate.
I designed it to fit in a particular space and for Eminence's Kappa 12A speaker and to see how small a "K" type might be built for a 12 inch speaker.
It has roughly 28.3 liters back chamber and 11.7 liters front chamber and I used hornresp's series bandpass model to make determinations.
Inner vent area is generous at ~27 sq.in. / 147.2. cm2 and the front aperture could be varied somewhat without much impact upon tuning.
For a little K-type with somewhat smoother response I believe adding a stub or tuned resonator would help matters.
This kritter should make a fun little bass guitar box - or bottom for electronic drumkit.
(I would use it in a -four-way K-stack - 35-80Hz = KUBE18 - 80 - 300Hz = KUBE12 - 300Hz -1500Hz = 8 inch K-midrange - 1500-15000Hz = K-tube.)
BTW, when making this type it could in some instances be useful to cut a "V" notch in the shelf vent per Nexo's patent for a smoother response.
https://patentimages.storage.googleapis.com/6f/8b/29/357e1bb79011ca/US20150222984A1.pdf
  • Screenshot 2022-01-26 at 14-28-24 1499072939623734451-US20150222984A1 - US20150222984A1 pdf.png
Not bad. The 250Hz front chamber tuning isn't that peaky. I'd tune the back a bit higher to even out the lower part of the gain bandwidth. The usual W-notches are very evident on this one. The internals are fairly close in volume to SK8. It's also similar enough to that mini-SK8 I never built, so am glad to see it work out in a bigger format. 🙂
How is it subjectively?
dunno yet on SQ as need to figure out either a K-tube or horn on top plus xover. Also am really limited for freedom of movement with the Dayton USB mic's 10ft cord tethered to a desktop pc.
I need a lowpass favorable to Kappa12A and this K
can only tune "down" as the back and vent are glued - lucky to be as good as it landed.
It might be interesting to line both sides of the vent with melamine sponges.
There's no damping materials yet save for a few melamine sponges on half of the cabinet's bottom. Where might addtitional
sponges be most effective? (I'd like to hold off the back of the wings til "last")
with health issues and no access to wood for even simple blocks, its going slow. I think Kube12 may play well with my Beyma 1.5" drivers and 1.5X scale K-tube kindly made for me by Pelanj - but want to introduce a midrange K-coupler and if could saw and had space I'm in a little mobile home) would make a "KUBE18" for comparisons and combinations with KUBE12.
Pelanj also as a gift made a pair of 1"x 9" K-tubes - I don't yet have even a block to mount them at an angle but will try to find a 2x4 scrap. Doing a sine sweep of that tube a few months ago with PRV's inexpensive ring radiator, I could feel in my body the tube's power.
I wish I had the brainpower and skills to run Akabak 3 to see if there's cavity and aperture combinations for 4 inch to 10 inch driver size which play smoother than others. My current midrange module is K8 with B&C 8pl21 and it exhibits two major dips even without the aperture.
The interest in a multiway Karlson approach stack comes from wanting realistic timbre and dynamics playback of guitars - piano - drums, and benefits from distortion reduction can be dramatic,
So - a 3 or 4 way Karlson stack even before the subwoofer could be much fun.
with a $40 Kinter 2.1 3118 amplifier plus two "K3.5" w. 4 ohm 3fe25 drivers , Kube12 makes a fine little 2.1 system - - not deep but not muddy and plenty of volume on the low end from drums and organ pipe sounds. It should also make an interesting FAST or 3-way. Different apertures would be worth exploring including a keystone when running wider range than "helper woofer".
Reactions: pelanj
