Karlson koax driver
Hi all there out
me playing a Gotrian grande, a five string contrabass and horn. Jazz, Rock, a bit classic. do have a smaller AMS Neve mixing desk, a Phillips pro 36, two OTL tube amps.
Other old stuff, a bit digital.
Meeting a guy with a 12'' Karlson speaker an old one.
Blown away. A virus? Magic.....
Why?
Horn speakers tend to grew big.
Hifi speakers are sondwise thin 4 me
DSP speakers sound dead to me. No "charm"
A Karlson with a good koax could do the trick.
Maybe bottom to bottom right and left.
In Italy found someone with old Karlon and somting like an "university coax driver" amazing
Crazy I'm hooked
With a new Koax driver HiFi or PA dreaming
with the right coax (or fullrange - or woofer + K-tube) , its one of my my favorite ways of getting music. I also like front loaded horn systems.
For "K12", I've not tried the "Dutch" variant. I probably have 8 or so of Karlson's K12 design, GregB's Karlsonator 12 pair.
I'm surprised they aren't more widespread - I've owned large Acoustats with hybrid amps, Tympani 1D, Magnepans, K-horns, Rogers, Spica, Quad, Phase Research, and pieced together horn systems, yet the original Karlson cabinets (K15, K12 & X15) often remain among my favorites and my next speaker will be a Karlson type. Nothing sounds better on bowed or plucked bass viola than K15. It must be braced well - like any other cabinet.
I don't think the 6201 had much motor strength and some examples today may have weakened over time (?) - the 15" University coax with large motor should sound wonderful. Even the old cheap Nirvana Super 10 is a good player in K15. I did not try it in K12 as its frame is meant only to front mount. Super10 as very good in the Karlsonator12. I think Fane's double whizzer fullrange 12 and 15 will play acceptably in K15 and the 12 fine in K12 (sans bass impact)
I have the new PRV 10" fullrange in a "K10" size but think it would sound better in Karlson's real K12. Karlson cabinets with a good match sound wonderful - - the wrong speaker will not work and some attempts to make the type can be tricky.
K-builder Carl Neuser would typically test 3-4 sets of wings for a given coupler - I don't know his testing criteria but do know that the aperture flare can matter quite a bit and make or break the result, so a new K-coupler probably should undergo some subjective testing rather than just gluing on the aperture and assuming everything will be optimal.
There are a couple of guys who make a high end horn system, one had never heard a Karlson, old K15s were loaded and topped
with vintage RCA horns (I think with field coil drivers) - he said it sounded better than the top of the line Wilson speaker.
I've used a few horns on top of K15 - some sound very good - my cone driven tractrix did not. The combination
had the power of a good horn system, better transient response, and much better sound than any FR I've heard.
But - they aren't popular.
that looks pretty pricey. The old one inch distributed source Smith horn in its original orientation sounds pretty good on top of a Karlson/ K-type.
Using a K-tube is good. They just should not be crossed over very low. A K-tube can be placed:
Above the wideband/woofer as Karlson did in his 1965 - 1973 (death) "X15"
this is a "near" X15 copy - the builder accidentally moved the woofer cutout 7/8" upwards - otherwise its pretty close including a cloned K-tube. The cabinet with the blue "wings" is an Acoustic Control 115BK and sporting an extended
version of one of the original X15's tubes. That tube sounds fine but the diameter transitions
muck with its smoothness. Its better to have a tube the same diameter as the compression driver's exit.
On top of the cabinet like Transylvania Power did
soundl12-jpg.1850964
Or through / extension of a standard coaxial speaker
one would have to try to smooth the transition between the original coax's
horn insert or replace it with a K-tube. David A. Young who used to post at
Job Uflman's old Karlson Speaker forum, converted several coaxial to "koaxial" with K-tube. On the low end, the K-tube could have less output than a little horn.
Wolf von Langa was excited about the K-tube but I think he figured it might be difficult to "sell" to the general public.
For the experimenter on the cheap side, car coaxial with dome tweeters can be easily converted to koaxial with a slotted pipe K-tube
In this video you can see that I used a straight section of pipe to extend the little 5.3" long K-tube so it would reach the main aperture. That removed a lot of the klam's main chamber influence. This particular klam for a 15cx turned out ok and sounds pretty good without the K-tube. There was no attempt to made a smooth transition for this experiment as the coax was already in my klam. I just crammed the pipe down the horn's throat and let it "sail" 😀
YouTube
Ok, I'm not looking to go cheap. Not using old drivers I do know quite nothing about. TAD is even more pricy
Hmm, for 5 string bass, you ideally need a ~ 31 Hz Fs, so probably best overall option is one of the coaxes the K15 was designed for; the Altec 604 series, which is still made by GPA in modern form and a pity you didn't post a few weeks ago before their 'across the board' huge price hike, ergo will at least give you a frame-of-reference if too far over budget:
Products - Great Plains Audio
https://greatplainsaudio.com/wp-content/uploads/2016/06/604_8H_III.pdf
If more mids presence is desired, then add a mid horn on top and XO for a three way.
GM
Charles Mingus once told, keping things simple is genius! Making them complicated every idiot can do..........If I go this way I has to be two way.
Most monitoring speekers are two way. The rest HighEnd Nirwana...my five cents...sorry My five string bas is simple my big Gotrian two. no keybord can do this! All electronic stuff is great, I love them. To express other feelings. Dreaming, angry, explosing, crying out, you can do only with real instruments........
- - If you are just using a high quality woofer, then even a cheap compression driver can give good results with a K-tube either inside the front chamber or on top of the cabinet. Here's an 8 inch K with tube on top.
GM - what might I do to make a new "K10" with very little emphasis in the 220Hz region? An additional chamber could be added to the front chamber. There was a curved reflector in this cabinet. I might take Art Welter's dad's interpretation of a "K8", load with Delta Pro8a and compare.
YouTube
Hey Freddi, I still have two uncommitted P-Audio BM15-CX38's. Reckon they could work in A Karlson type cabinet ?
They are spectacular in the MLTLs I built.
Active (MiniDSP) crossovers.
Specs here:
P.Audio Coaxial Speakers - P.Audio BM15CX38 coaxial 15" speaker - P.Audio BM15CX38 500 watt 15" coaxial speaker for all full range applications. P.Audio BM15CX38 15" coaxial and other P.Audio coaxial speakers here.
I have two of these, open baffle above two Sigma Pro in vented cabinets.
Could you give me the details of your MLTL's?
those would work fine as long as they have a nice clear midrange - you will give up LF extension vs a larger MLTL - but the bass you have should be good. I have a P-Audio SN15X in a Karlson. Les Hudson used the BM15CXA.
Don't recall any K10, but in general, to limit HF gain is to use a driver with an upper mass corner at least a 1/2 octave below it. A band stop filter and maybe some form of EQ if chambered is all I can think of ATM[scroll down]: http://users.cms.caltech.edu/~ps/All.pdf
GM
Here's old pictureS I dug up of a little homemade "Rocket" type K-coupler loaded with a Polk 5" AND 6.5" coax. There's a K-tube mounted over its 1" dome tweeter.
I'm guessing the coupler slopes are 6 and 12 degrees like the old Karlson KR-5 "Rocket"
Polk's coax sound pretty good in regular Karlson (sealed back chamber) and the 6 inch variety
should be decent in 8 inch klam.
6.5" cOUPLER
5" COUPLER
