Just about to start a pair of Mar-Ken10 cabs.
Are these the correct surfaces to line in felt
+ the top and bottom faces?
You would partially occlude the vent entrance with that scheme. I'd make the side pieces 10-15mm shorter, and the back piece such that they end where an extension of the inside of the inner side would hit the back.
dave
dave
Awesome. Thank you!You would partially occlude the vent entrance with that scheme. I'd make the side pieces 10-15mm shorter, and the back piece such that they end where an extension of the inside of the inner side would hit the back.
dave
