Kairos & Sb Acoustics Ara?
I have considered an MTM for that room. Any negatives to a speaker of that size in a small room?
Kerry, when will the new kits and mods be available?
Will the upgraded 2TD be available at the same time?
Are the crossover changes for each speaker anything more than changing a couple of components and are the capacitors/inductors likely to be bigger. I was really tight for space in the 1TD with my crossovers.
The 1TD-x will likely be available sometime later next month. We are finalizing the crossover and then have to design the boards and packing. We are working on the updates for the P215 and 2TD now but they will probably come afterwards.
It will be a new crossover and board, since the boards are designed specially for the parts used. You would swap the whole crossover and tweeter.
Thank you Kerry. I'll keep a check on the CSS website.
Just to dig back to the topic of the ARA. The crossover diagram can be found in the info book:
http://sbacoustics.com/wp-content/uploads/2020/02/Manual-ARA-kits.pdf
I think it is neat to see a comparison of the two drivers on the same body:
I am currently thinking of using the two drivers for my first project and falling back on the ARA if my measurments stink.
