I wonder if any one worked and succeeded into the K6 switching power supply,
www-a-and-t-labs.com
I built this supply from scratch, but the mosfets burns at 3 amp draw .
I dont know why!?
I connected my amplifier, put some music at high volume 4 Ohm load.
30 seconds playing. watching the multimeter, at 3 amps , the fuses blown, check mosfets, they are gone!!
they get very hot at low current draw.
Any comments?
I dont know why!?
Any comments?
There are several bad reports on this particular power supply. Do a search and you can follow the threads.
H
this design is trick, it will not work unless you buy the original transformers, (I dont think it will work either)
i am moving to a new design now, IR2110,
