"" JVC XL Z574bk cd player tweak it !!! ""
JVC XL Z574bk cd player upgrade !!!
Hello guys,
I own this old CD player, still working. I do it on an upgrade, with budget of € 50/100. Where do I start ... I await advice ...:up::up:
Not much, at least you may follow Mooly's advice, such replacing Opamps -on which subject M. himself opened a thread about the pros and cons of doing it-
I only limit myself in replacing the output caps, which is already a hard job considering the fragility of the pcb lines.
with a little magnification, you may recognize the 3 stages ( ? a cap ! )
before the output: from it, the muting transistors ( they might be replaced by a relè, or reed ) then the coupling cap, and the 2nd order lowpass around the Op-Amp.
Maybe...a LC network instead of the 20-22 kHz active lowpass :scratch:😱
