JVC-FX1010 poor sensitivity
Hi all,
I've got the 1010 in a multi tuner system and having had one before it's obvious that this one has issues. It barely registers any stations across the dial where even my most basic tuners will grab all the major and local stations using the same aerial feed. Dropping the tuner into local mode drops any received signal down to 0db even if it was over 30db to start with which I only get on one station. Would I be right in thinking a filter is down or am I going to have to get an alignment done?
Thanks Mat
