jvc ax-411 repair help
Hello to everyone,
​This is ​my first ​post,
​S​orry my english is not so good :)
I have an antique JVC and Ax-411 amplifier.
I saw one of the channels didn't work.​ I ​check​ the​ board ​and I ​found R769​ ​(10ohm) resistor fail​ed. ​ I've changed with the new resistor​ but they got harmed.
​N​ow two output transistor and 3.15A main fuse ​are burned.​
​You can find the ​chart​, attached.
Does ​it ​help?
