Just won a AB International 600LX, what to check first?
You could get the schematic , check offset /bias.
AB 600 series has 3 similar "leach amp" type circuits. Older 600
has no servo (below - the "a").
LX might be a round toroid and a servo - same amp with 3 pair
BJT TO-3 outputs.
OS
So you're the one that out bid me (by $1)!
Power it up and check there is no DC on the speaker outs (before hooking up speakers).
Use the 1/4" inputs, not the balanced (unless you work on them).
Clean the input jacks and front panel pots.
Hey djk, I guess you would be the one to ask then. I'm running a set of Cerwin Vega 6 ohm speakers. The plan is to get another identical set and run them all off the same amp. How would this amp be running a 3 ohm load? I have heard 2 ohm is iffy.
If you measure those 6Ω Cerwin Vega, I'll wager that the DCR will be under 4Ω, so two will be a problem.
You could buy a different transformer, a 40-0-40V 800VA~1KVA unit would allow the AB 600 to drive 2Ω safely. It might be cheaper to pick up another amp.
