Just found these... any use in Tripath amps?
You need fast capacitors for class d amps. Like panasonic fc or sanyo oscon etc... because class d chips need energy & they drain the caps reserved energy fast.
If what you found is for free, i would use them for circuits with voltage regulators & small power supplies.
A modern electrolytic 330uF 35V capacitor is ~ 10mm dia, ~ 20mm long.
They are so cheap its not worth using very large old electrolytics.
A modern 3300uF 63V capacitor is about than size.
Really not much use to anyone, except a vintage restorer.
rgds, sreten.
