Just another RIAA......
Some time ago I posted a thread where I asked if anybody had any opamp based riaa design to recomend. I got a few answers and paulb gave me the following webadress:
http://www.national.com/an/AN/AN-346.pdf
I decided to use the design described in this application note. This design is a two stage riaa phono preamplifier.
Currently I use BB opa 37 in the first gainstge an BB opa 606 in the second gainstage. The result is shown in the following pictures.
RIAA...
However it has a somewhat enhanced s-sound. I wonder why ?
Did you try other op-amps? Or (DC-blocking) caps?
I have just finished off another "Bugle", running it in now, and it sounds fine w. RIFA caps & AD825 op-amps in and out, and a "cost-saving" OPA2134 inbetween.
Arne K
NORWAY
peranders said:
Have you been able to eliminate the vinyl itself? Is it the new amp or is it the LP?
Have you checked the input capacitance? Maybe you need a trim? Some pickups needs up to 400 pF.
Hi 🙂
The pickup i use (ortofon om 10) should be loaded with about 100 - 200pF. I have tried both values with no real improvment IMHO. Currently I have no load capacitance and it`s better I think.
Could it be that the cable I use introduce enough capacitance ?
Normal TT cable has approx. 100 pF per meter and must of course be included.
If you connect the TT to an another RIAA amp, do you get the same S-sounds?
I salute you also to your achievement (I can feel the joy you feel) but unfortunately your wiring doesn't get any high score. NEMKO had :no: their heads. Think tidyness. Separate 230 volts from the rest. NO unisolated parts!
Which circiut have you built? The last one in the application note?
:up: Does it work yet?
Arne, do you have DC-servo PLUS capacitor? Either one fat mama or DC-servo. Check carefully how you choose between "Linear Tech original" and "P-A original" feedback network.Check here and the part about DC-servo.
Note also parts for optional compensation.
We had a diy party when we used my monster QSXM2 together with a homemade TT with tangential arm. Look at the painting of the TT! I thought it was plastic imitation. :cannotbe:
We hadn't time to REALLY listen to the amp or TT but it didn't sound bad anyway. The power came from two norwegian Mascot lab PS, not very high tech.
http://www.hififorum.nu/topic.asp?TOPIC_ID=14408
I suggest that you make the DC-servo working as intended, remove the C11, C12, C13. Use not R5, R23.
You may otherwise get the "golden ears" haunting you. You must achieve accurancy below 0.1 dB! 😉
More gain:
MM R6, MC R4. Half the value double gain = 6 dB
MC has 20 dB more gain. Note the differnce between R6 and R4.
Chris said:
The sound is nice. Good soundstage, relaxed but dynamic..
The Ortofon OM10 is a bit sibilant, that's almost certainly the cause of your "enhanced s-sound." I had an OM10 in an SME3009 S2, and had the same problem, so I changed the stylus for an OM30 stylus (the bodies are identical), and the problem went away.
Yepp, I did the excact same thing:nod:
Re: QSXM3
And it also sounds great ! Now, I need to find a home for it (chassi).
A little gain-adjustment 100ohm -> 75ohm was what I needed.
All components are matched, even had to order another 10 of the RIAA caps for getting a match...
Arne K
