It will not dissappear and everything else behaves well!?!?!?!?
Start Turn off you METCAL solder station!
AAARRRRRRRRGGGGHHHHH ....
I have used a whole day on this!!!!
Any idea why????
My solder/desolder station puts some really nasty stuff on the AC line. You ought to see what it does to a circuit without good regulation.
Jocko
Jocko
The metcal works by generating a HF in to a coil mounted in the soldertip the metal then generates heat at a very precise temperature..
For the same reason the cable to the solder tip is some RG-type coaxial cable....
Maybe a defect in the screen...
this belongs in the "Engineering Humor" section
like the guy who had to get a project done, working at 3:00 a.m. with the soldering iron placed on the schematic rather than the PCB.
Sonny,
could you describe your problem a little bit more exactly 😉
You can send an e-mail.
Cheers, Pavel
Cheers, Pavel
- Just a little note : When you wideband amp oscillates at 200KHz and you dont know why
