HELLO
GREETINGS i am a new user using SPRINT PCB software is it possible
to convert jpeg files into lay files please any one know if its possible and what
software i need to convert files
warm regards
andrew lebon
warm regards
andrew lebon
Nope, but you can convert the JPEG to a bitmap and use it as a background, then manualy recreate the board by tracing the routes over the bitmap.
Sprint-Layout
Sprint-Layout
THANKS
Hi marce
greetings thanks for replying please can you tell me what is SCHEMATIC CAPTURE in pcb software have you used PULSONIX pcb schematic
capture software
warm regards
andrew lebon
Hi marce
capture software
warm regards
andrew lebon
Hi Andrew,
I use Cadstar daily and ORCAD/Allegro occasionaly, when forced too.
Schematic Capture is for entering the circuit diagram, this should then transfer directly to the PCB layout part of the software.
I havn't used Pulsonix, worked mainly with Cadstar for 27 years now.
Marc
Marc
