I found a possible DIY TFT-canidate. And again there is no hard evidence that it is high res, but everything is pointing in that way:
JOYTECH 7" inch universal tft
7.0” Active Matrix TFT Screen
PAL and NTSC Compatibility
RGB SCART, S-Video, Composite and Stereo Audio Inputs
SRS® WOW™ Surround Sound Effect
Mylar Cone Hi Fidelity Stereo Speakers
Twin Headphone Outputs
Comprehensive On-Screen Display
Table Top and Wall Mountable
12V In–Car Power Adapter
manual:
http://www.dbline.it/Joytech/guide/7inch.pdf
link:
http://www.gameseek.co.uk/productdetail/Cubeb4vkwe9ga7vxqmqj/#specifications
So what do you think?
It would be great for european people, because it can just be bought in the shops. Here in holland it costs 199 euro.
manual:
link:
looks pretty good, RBG input probably compairable to VGA input in terms of quality. i think you can get a cable to convert VGA - to SCART but it might be as simple as matching the pinouts.
I got a mail back:
Dear Sir/Madam
Thank you for contacting JOYTECH Technical Support.
The screen accepts inputs from S-Video, Composite and RGB signals.
When usinga TV out connection from the PC using S-Video cable, the screen accepts 640x480, 800x600 and 1024x768.
1024x768 was shown to display full screen output which provided a nice sharp resolution with clear text.
We hope that this is satisfactory, and that you continue to use and enjoy all of JOYTECH's peripherals.
Kind Regards,
But does this mean that it is native 1024x768? it's 7" so I gues not. But i don't believe it is 380x240.
Dear Sir/Madam
Kind Regards,
Why is that so hard to belive? I think that if the tec suport wont tell you what it is its prolly hella low (i wach to much south park; i cant belive i just said "hella"
it would be cool if im wrong but i doubt it,
Aidan
Aidan
The Alchemist said:I got a mail back:
Dear Sir/Madam
My tv does the same thing, it just depends on your videocard.
Clearly the person who send this email does not know what he is talking about.
The resolution of a PAL signal is 720 * 576.
machs_fuel said:looks pretty good, RBG input probably compairable to VGA input in terms of quality. i think you can get a cable to convert VGA - to SCART but it might be as simple as matching the pinouts.
Price is $199 CAD for any Canadians who are interested.
Anthony
Actually i bouth this lcd panel for 100 cyprus pounds about 60 euros and i used it on my overhead projector 250 watt 2750 lumens bulb and i have good results. i believe that in the future when i ll retrofit my ohp to accept 4000 lumens bulb i m going to have even better results. I use a 3m 910 ohp which is kind very old ohp so its necessary to upgrade it . The good thing about this lcd panel is that u can connect it directly to your tv and get tv signal. Just connect it to the tv using scart cable and watch tv 🙂
U can connect everything else also. Ps2 ,xbox , pc
If you have any questions mail me at jannacs7@cytanet.com.cy
actually to give this thread a final solution; this tft only has a resolution of 480x234 dots and is way to expensive for this low resolution... here is the specifications text
JOYTECH introduce the final word in cutting edge Portable Monitor technology, with the Universal 7.0inch TFT Monitor. Expanding upon JOYTECH’s recent success within the Video Game Monitor sector the new Universal Monitor takes Portable Display Systems to the next logical level, offering total freedom, flexibility and choice for on the move viewing. Incorporating a high definition 7.0inch active matrix TFT screen, the Universal Monitor comes complete with JOYTECH’s bespoke AV Cable, ensuring compatibility with virtually any external AV source, such as a video game console, DVD player, Camcorder or VCR. With stunning Slim-Line looks, and quality of paramount concern, the Monitor comes complete with integrated SRS® 3D Surround Sound, OSD (On Screen Display), and even an RGB input for sensational picture quality and colour reproduction.
Product Features:
• 7.0inch Active Matrix TFT screen 336,960 Pixels (1440 x 234 – RGB)
• Multi Region compatible – NTSC and PAL
• S-video input, RGB/ Audio input (11 pin DIL socket), Composite AV input (4 way jack socket)
• SRS® stereo surround sound effect
• 5W RMS built in stereo amplifier
• Two 40mm Mylar cone Hi Fidelity speakers
• 2 x headphone outputs (0.25W)
• On Screen Display (OSD) – Volume, Mute, Input, SRS Bass, SRS Width, System, Brightness, Contrast, Color, Rotate screen.
• Anti-Glare/ Non-Reflective PVC screen
• Power button and indicator
• Unique “fold-out” aluminium desk top stand
• 12VDC In–car power input jack
Accessories included:
• AV (composite video and stereo audio) system input cable with Gold plated female RCA connectors - terminated with a 3.5 way jack (2metres)
• RGB/audio system input cable with female Euro SCART adapter - terminated with 11 pin DIL socket (2metres)
• S-video to S-video system cable (2metres)
• 12VDC In-car power adapter
• Protective case for Monitor
Specification:
Power Requirements DC 9-12V via external AC Adapter 1000mA
Electronic power consumption 10 watts
External size mm
Weight 0.66Kg
http://www.dabs.com/uk/channels/hom...sandprojection/productView.htm?quicklinx=3162
Product Features:
Specification:
External size mm
Weight 0.66Kg
OK, if anyone used this monitor for his project like i did, reply here or email me to discuss about the results
Hi, i'm in the uk, i have some light kits, 400w and 250w and some condensors if anyone wants them, cost price no profit being made, get in touch if you want one, i have 4 left, and there going like hotcakes,
cheers
cheers
wily i have to admit that i completed my setup after downloading your pics and seeing your setup.
my setup its the same like yours except that i use 2 fans and 250 w bulbs. unfortunately i dont get a good bright image. my output its a little dim and i m wondering if i upgrade to 400w bulb how its gonne be the result with this particular monitor.
- General Interest
- Everything Else
- The Moving Image
- LCD
- JOYTECH 7" inch universal tft - again a possible kanidate
