This is my first time on DIYaudio. I am from Perth in Western Australia. I have just built the transmissio line box as designed by ted jordan. I have put foam behind the driver as he suggested. Do I need to put in any more stuffing before I close up the box. Do I need to tune the box by adding sand etc. or will it be ok as is. Cheers Peter
This has been discussed on the FR forum
http://fullrangedriver.com/tiki-page.php?pageName=FullrangeIntro
the archives are a bit hard to get at, but people will chime in if you ask...
dave
dave
pstephenson said:This is my first time on DIYaudio. I am from Perth in Western Australia. I have just built the transmissio line box as designed by ted jordan. I have put foam behind the driver as he suggested. Do I need to put in any more stuffing before I close up the box. Do I need to tune the box by adding sand etc. or will it be ok as is. Cheers Peter
Hello Peter
You need to give the speakers time to burn in
and experiment with the stuffing
Do you have picture's and drawings
Greetings Weidok
http://www.quadesl.com/tidytl.shtml
