Hi all,
Something bad happened to my Jolida 502A last weekend. I was listening to it for about 4 hours when I wanted to turn it off. The switch was blocked and I was not able to turn it off, so I forced it a little and I saw smoke so I quickly unplug it from the wall. Since then, I am not able to turn it off, the switch is like mechanically broken.
Do you have an idea what it could be and where I could find a switch to replace this one ?
Picture of my amps:
http://www.responseaudio.com/502pic.jpg
Thanks,
FLEO
Picture of my amps:
Thanks,
FLEO
Do you have an idea ... where I could find a switch to replace this one ?
Mouser Electronics - Electronic Component Distributor
Picture of my amps:
That's not a very useful picture. Why don't you take one of the switch in question? Perhaps with some measurements?
My 302b is up on the bench with the bottom off. I managed to pry out the switch to get the number. Your's will probably be the same:
SWITCH ROCKER DPDT ON/ON BLACK - GRS-4022-1600
Jeff
Jeff
