I tried drilling for screws, but the MDF still swelled and forced the layers apart when driving screws into the material.
Here's something which worked beautifully for me. Drill quarter inch holes in the wood and use hex nuts & bolts to hold the layers together. Bolts with a plain area below the head of at least an inch, and better yet an inch and a quarter, are preferred. You want to use washers on both sides, of course. Here's a tip: wrap the washers in duct tape to keep excess glue from sticking them to the MDF. For some reason bolts loosen easily from the holes but steel washers glue surprisingly well.
Once the glue is dry - I waited a week in summer, three weeks in a California "winter" - you can plug the holes with quarter inch dowel pins and cover any remaining gaps with your preferred screw hole filler. The technique is a bit more involved than using screws, and a bit of a pain in the neck when working around long ducts, but the results are worth it.
If you are going to screw it together to hold it then I support jimbro, countersink both sides.
In addition I would suggest removing the slightly shiny finish fron the sheet faces to be joined, a quick sand with 60/80 grit on a ROS will do the trick. Spread PVA glue of you choice (i use exterior grade always) evenly over the surface and then just clamp together, for wide, long sheets throw a couple cement bags in the middle to add pressure/weight. With a supply of clamps screws are just not needed.
The last lot of speaker cabinets i built have no screws at all holding the MDF joints, just biscuits and glue.
Phil
Phil
I used construction adhesive but put in pilot holes before gluing, to make sure everything is lined up, and were countersunk. Warm up the adhesive before using and use thin lines of the stuff - about 1/8" wide and 1/2" apart as even as you can. I used a 1/2" wide piece of wood to draw lines and that made it easy. Try on a scrape piece of MDF and you will see how strong this stuff is!
Peter C.
Peter C.
Do not use screws. There is no reason to use them and they can cause problems. Take the previous advice of glue and clamps and a little sanding ahead of time. Consider also full panel coverage with the glue using a putty knife, not just ribbons. You want a nice thin film. Pilot holes drilled for alignment is fine but are not really necessary and you will have to redrill them anyway to clear them of glue.
As Cal suggests, for best adhesion and to prevent slipping when clamps are applied, pre-sand the case-hardened surfaces of MDF ( 80-100G would be fine) . Personally I use a lint-free velour paint roller for spreading glue to both surfaces - the result is a thin very lightly stippled film which is far less likely to creep than the ribbons. A couple of brads from an air-gun will help keep the panels in alignment while clamping up - and don't forget to use 2x4 etc cauls to evenly distribute pressure
Recently did a pair of OB baffles using two 18mm MDF 1200x410mm per side using glue and clamps, no problems. Did both at same time and used 2x3 to distribute clamp pressure as Chris as mentioned.
Did one sheet slightly larger, the use router with bearing guided cutter to match the sheets (the larger one to the very accurately cut master baffle).
Same technique should be good for joining to layers of plywood? IIRC ply is a tad less slippery vs fibreboard/mdf after applying glue.
Chris is the real expert so I really like his ideas of using a roller (albeit a throw away item?) and the suggestion of brads to keep it in place before you clamp and 2X4's for the pressure distribution.
Thanks Chris.
I would try a notched trowel for spreading the glue evenly.
I imagine the problem with screws is that the threads made by the screw in both sheets don't align, possibly forcing the sheets apart to some degree, but this can be overcome by drilling a larger pilot hole in the top sheet...
Thanks Chris.
Cal,
Just to let you know, I will now start calling 'extended clamp pads'... Cals
good technique though. scuff, roll and clamp
I use a 90deg jig to clamp down the wood and hold it square, wax paper keeps the glue from sticking to the jig.
For multi-layer laminations done at home, consider cutting an array of narrow, shallow dado grooves along the length of the board so that the excess glue has somewhere to go, allowing for closer clamping.
Perforating one of the boards also will work, but it will take quite some time even with a drill press.
- Design & Build
- Construction Tips
- Joining two MDF for the baffles
