john curl said:...We use the VERY EXPENSIVE TKD pots that are only obtainable from Michael Percy (at least here in the USA). They cost over $160 each! We need two for each preamp. Still, they sound darn good. ...
Hi John:
This is an interesting thread. 😉
What I'd like to know is whether you are using Shallco switches in this preamp of yours? Any particular reason why you chose to use TKDs and not stepped attenuators?
Thanks for sharing,
Milan
Upupa Epops said:Yes Peter, I'm serious and that's just it I need explanation - from you I din't get it... 😉
But why do you need it?
moamps said:Any particular reason why you chose to use TKDs and not stepped attenuators?
They are stepped, regular TKD is only $60/pc
Don't do that.
Hi Peter,
-Chris
Where do you buy your controls?They are stepped, regular TKD is only $60/pc
-Chris
Those controls are from percyaudio.com
The stepped TKD is sold out now, I didn't have a chance to try it out.
Hi Peter,
Thanks, I was hoping you had a local place to buy them. One never knows where these things turn up. 😉
You anticipated my next question as well.
-Chris
-Chris
Peter, the TKD mono pot (stepped attenuator) that we use in the CTC costs $169.00 each. Please look at the latest catalog. We just bought one last week. There is a cheaper TKD, which we are designing into the Parasound JC-2 in order to REPLACE the Alps pot used previously, and it costs about $60.00
Folks, I might say something about pots.
Back in the '60's we usually used Allen-Bradley baked carbon pots. We used them exclusively at Ampex and for virtually every pro audio application. When I met with Mark Levinson in 1973, he was using a very expensive dual pot (for the time) $20.00, because it TRACKED better than any other dual pot, at the time. To improve tracking further, Mark used a linear taper pot (100K) with a 50K load resistor as a load to make it into a sort of log taper. This idea was given to him by Dick Burwen (sp), and it worked very well.
I got my Levinson JC-2 in 1974 and I put it into our professional sound system that we were developing at our lab in Switzerland. At one point, in one listening test, my associate, John Meyer and my other associate Bob Minor, (his father used to be my audio mentor) both told me that something was wrong with the sound of my JC-2 preamp.
WHAT? My preamp is virtually perfect! I exclaimed, but they were insistent about it
So, I said "Don't touch anything!" and I carefully took the preamp to my test bench, WITHOUT changing the controls. Well, guess what I found? DISTORTION! and lots of it. It was in the POT, but only at certain positions on the pot. Full on, or over most of the range of the pot was OK.
Flying back to the States, I tried to tell Mark Levinson about my finding. He was very resistant, so I rubbed his nose in it by taking a pot off his assembly line and measured it with his test equipment in front of him. Mark was converted.
I started to measure all kinds of different pots, and I found that many of the Allen-Bradley pots that I had stocked my lab with, failed! They had significant distortion at certain positions of the pot. I also tried some Bourns pots, that looked almost exactly like the A-B pots and they were OK. What is going on here?
Later, Alps pots became available and they measured great! Yet, over the years, I found that they did not sound right, for my best efforts. Still, they are practical, track OK, and have very low distortion. Personally, I think that it is the substrate that they use that makes the difference, for some reason. I have much more experience about this, but you should understand that something can even measure OK and still not sound exactly right. Go figure!
PMA said:Michael,
what you wrote about me is only a part of truth. I often listen to classical music and I do not like it through tube amps. I can even tell (recognize) that recording was done through tube preamp. Me personally I am bored by euphonic sameness of the tube sound.
I said that low distortion is not the only satisfactory condition for a good sound, but id did not mean I liked the tube sound.
Pavel
Pavel,
What are some reference CD's you use and would characterise as
transparently recorded.
I'm interested in what you like to listen to.
Terry
And how this phenomenon depend on ohmic value of these pots ? How it depend on concrete mechanical construction of pot ? How it depend on construction of collector ? By which attenuation you was observe it ?
john curl said:Peter, the TKD mono pot (stepped attenuator) that we use in the CTC costs $169.00 each. Please look at the latest catalog. We just bought one last week. There is a cheaper TKD, which we are designing into the Parasound JC-2 in order to REPLACE the Alps pot used previously, and it costs about $60.00
Indeed, mono pots are still available, I was refering to stereo, as I find them more practical. Although my setup for an attenuator was even less practical: http://www.diyaudio.com/forums/showthread.php?postid=863703#post863703
Presently I'm using S&B TX102 line stage with very good results.
john curl said:Folks, I might say something about pots.
Very interesting John.
I have never measured pots ans honestly thought that their
distortion would be -way- down, even though they all sound slightly
different. WRT Alps, I agree, I believe a good switched attenuator,
especially separately switching in pairs of R's, with something
like rohpoint non inductive WW R's is definately more transparent
sounding.
Anyone tried bulk foil R's in a switched attenuator?
Terry
Hi Terry,
I have tried (and presently use) Vishay bulk-foils, together with 2 Shallco switches in a dual mono arrangement which is coupled together with some gears. The result, sonically, is unbelievably better compared with any pot I have ever tried, and channel-matching is effectively perfect.
These include all the usual 'suspects' like Sfernice, Noble, Alps and Penny & Giles etc.
In my view, the cost and trouble is well worthwhile, and the only downside is that they are manual, as opposed to being able to be used with a remote.
I have considered motorising this switched attenuator, but even with weaker detent springs which I have also tried, the torque necessary would be beyond the means of any usual motor's abilities, regrettably.
I've been using Placette RVC for a while, which is relay based, with 14 bulk foil resistors in series/shunt combination (7 resistors activated at any given setting). It was very good.
Terry
Yup. Distortion measures lower than a normal pot. Sounds OK, too 😀.
regards, jonathan carr
- John Curl's Blowtorch preamplifier
