PMA said:500kS/s is a very low sample rate.
7.2V DC is a pretty high voltage.
Jan Didden
john curl said:It's not worth it, Joshua. See what I mean? Next time just Wiki the topic and get up to speed, and then they can't use it against you. It just wastes bandwidth when we let them get away with it.
John,
Your "us-and-them" attitude is teaching your impressionable disciples bad habits.
Anyone who disagrees with you or even asks for back-up or clarification is placed in the "them" camp (and of course that includes me). Who taught you that is the way to deal with controversy? I enjoy controversy but your cancerous brand of divisiveness is very different, and I hope you understand the difference.
I applaud people who may ask seemingly naive questions because that makes us think in responding and we often learn from that. I never answer in a condescening way. We often hear about the guy the experts forgot to tell that he couldn't do something, and went and did it. More power to that guy who maybe had the guts to ask a dumb question.
Not having a formal education in physics and being in the optical fiber transmission business, I ask dumb questions of those more knowledgable all the time. I'm not afraid to say "what do you mean I can't do that?", and every once in a while it turns out it can be done. That's the way the world works among designers from different backgrounds who show some mutual respect and patience for each other, and who try to walk in the other guy's shoes.
Bob
FrankWW said:Geddes is applying his metric to speakers and to whole systems but especially to speakers as quality evaluation tool because he believes the usual measurements aren't indicative of subjective experience of quality.
His metric can't tell us what exactly might be wrong with an amplifier and I don't think that was his intention.
All it can tell us is that there is a qualitative problem in the system.
Geddes is also using a cheap Pioneer receiver in his system.
FWIF
Bob Cordell said:
John,
Bob
This has to be post of the week.
Magura 🙂
Originally posted by anatech
Hi Joshua_G,
You are an engineer of sorts. You do the best you can without the required equipment to be sure about things and this has left you in the mindset that you don't need more to do your job. That's okay, because I understand where you are coming from. For many years I was also in a similar position. Doesn't make it valid though.
I knew I needed more, and I could accept I didn't know everything. I think that is the biggest difference between you and several others around here. Yes, you can do a job. No, you can not do that job as well as you could with the proper equipment and knowledge. Just as there is a big difference between "making something go" and servicing it to original specifications. A repair isn't fixed until it's adjusted properly as well. That is something I taught my technicians for years, and it's an important differentiation. I do respect that you work with what you have, the best you can. There is no excuse for someone who has the ability to do better, but doesn't. I have fired many technicians for that reason.
So many assumptions on your part.
You don't know what work I did until few months ago, you don't know with what measuring equipment I worked and what measuring equipment I have access to (though I don't own).
As an engineer, you should know.
I'm not an electronics engineer. I stated it over and over in this thread.
Maybe not everything, but most f it. These answers are strewn throughout this site, and it's up to you to find them. It isn't up to anyone to hand you the information if you demand it.
I'd let others describe your attitude here.
Curious question coming from you, as an engineer especially. Are you telling me all you have are tube amps? I read on another forum that you like the sound of Sony mid fi. You would not be alone there.
Please re-read it. You are distorting what I wrote, in the context written.
Also, some amplifiers labeled as "mid-fi" sound better than some other amplifiers labeled as "Hi-Fi".
Since this post of yours is so much personal, assuming and quote me falsely, I'll leave it at that.
Where you are coming from is clearly seen.
However, others do – it was done to me in this page and to this John wrote me what he wrote.
It may be of a service to read phrases in the context written.
And with good reason. I rarely write anything negative here, but you have taken this way far out.
If you stick to the discussion, no-one would go for your throat, but as you insist comparing apples to bananas, you get yourself in this sort of situation.
This discussion is obviously fact based, so anything that can't be backed up with facts, is off topic, and annoys the participators.
Magura 🙂
Yes. Geddes:
No hardly - I don't "favor it", but I was severly chastized for using it at RMAF when, in fact, no one really knew if it was any good or not. It works just fine as my measurements show. I would not use this amp for many applications, but it suited my point at the time, which was that loudspeakers account for 99% (well you could argue 98%, but you get my point) of the audio systems sound quality.
The amp is a Pioneer DSX-V912 - a receiver. The point is that it was on sale at Costco for $150.00. I bought several of them for home theater use. I used my test to measure the amps and they were quite good actually. Especially for chip amps.
I was measuring a lot of chip amps (a survey of capability) and most were pretty bad.
As a chip amp this unit deffinately stands out. It compared quite favorably to a very well engineered discrete amp that I also use.
http://www.diyaudio.com/forums/showthread.php?threadid=109147
I believe he was testing them for crossover distortion.
My point is that the Geddes's metric is a measure of subjective quality for purposes of evaluating a system. It doesn't tell you what is wrong with the innards. It tells you you gotta go look inside or choose another system.
Bob Cordell said:
John,
Bob
Magura 🙂
Magura 🙂
Bob
A very good post, I agree with every word.
Magura
You are so right, I applaud you.
BTW: I think its some posts from earlier today that has been deleted.
Cheers
Stinius
Magura 🙂
Mind you, this response towards me was for me asking what FFT is.
So, what are you talking about?
Hi Joshua_G,
My other comments were based on a previous response to my question about your previous experience. From what you had said, I shouldn't have been far off the mark. I was trying to figure out where you were coming from and presumed the best and most innocent. Because otherwise you seem to like controversy. That is sure from some of your other posts to other members.
Hi Magura,
Good to 'see' you. How is everything with you?
Very good observations BTW.
-Chris
Not true about my response to you. I very nicely explained what an FFT was, and compared it also to the analog equivalent. Did you find anything negative in that response at all? If so, please let me know.Mind you, this response towards me was for me asking what FFT is.
Hi Magura,
-Chris
Steve Dunlap said:
I feel that THD should be as low as possible before feedback is applied. I feel the same way about bandwidth, wide, not low. Since it is a trivial matter to get THD figures below 0.005% at high power and frequencies, without feedback, then why not? A 100KHz bandwidth? Why not 1Meg or more? Once again, easy, and without feedback.
You are very fond if inferring what you believe other people say. It seems now that you are saying that good THD and wide bandwidth are somehow detrimental to good sound - possibly even bad for the sound.
Good specs will be the inevitable result of a well thought out and executed design. Failure to get good measured results does not prove audio gear to be sonically superior.
Steve,
Curious interpretation of what I wrote, but then again I've never claimed to be the best writer there ever was. Perhaps I didn't make my position clear.
In solid state gear, I usually look for about 200-250kHz bandwidth, minimum. I usually come in higher than that--400-500kHz. I can get away with fairly wide bandwidth because there's little RF where I live. I've not done a formal study of what's on the market, but I've got a sense that the 'average' bandwidth these days is around 100kHz. Spectral used to be the outlier in the commercial realm--possibly still is; if I recall correctly, they ran about 1Mhz bandwidth. Most others came in less, usually by quite some margin.
When I post a circuit, I either purposefully limit the bandwidth to 100-150kHz or warn people to be alert to potential RF problems. Ideally, I'd like the "DC to light" cliche, but we're getting more RF, not less as time goes on and the day may come when I have to pull things down to 100kHz. So far, I'm okay. From what you're saying, I'm assuming that you live in an area where RF isn't a problem. That's cool. But criticizing people for not meeting your bandwidth ideas is not necessarily a particularly good idea, as it could lead to fried circuits and/or tweeters, not just lower sound quality. Most people seem to think that I'm lunatic fringe for running .5MHz bandwidth. If you think that's too low, and if your living conditions permit, then by all means go for it. I'll support you when everyone else starts yammering about how crazy you are, because I happen to agree with you.
I'm not quite sure how you got the impression that I believe low THD to be detrimental to sound quality, but...my philosophy is that if I want ice and water freezes at 32 degrees, then 25 degrees is sufficient. If you feel that 10 degrees produces better quality ice, then by all means make it as cold as you like.
Grey
anatech said:Not true about my response to you. I very nicely explained what an FFT was, and compared it also to the analog equivalent. Did you find anything negative in that response at all? If so, please let me know.
And even more - find out Joshua that the moderators are so far defending you, saving some embarrasment. A few corrosive comments after your FFT question ( mine included, and for just cause 🙂 ) were deleted shortly after posting.
GRollins said:Most people seem to think that I'm lunatic fringe for running .5MHz bandwidth.
Don't worry, that's not the reason 🙂 I am currently running 8MHz unity gain for a 200W power amp, and nobody said anything about lunatic fringeness.
Yepp some posts were deleted, I wonder why, and who did it?
Cheers
Stinius
Hmm, this looks to me like merely another attempt by JC to get the discussion back on track. Good cop, bad cop?
Come on JC, I'd rather read "their" pointless banter.
Steve Dunlap said:Since it is a trivial matter to get THD figures below 0.005% at high power and frequencies, without feedback, then why not?
What nonsense. Please show me an open loop amplifier (say rated at 50-100W) that does below 0.005% THD at high (rated)power and frequencies.
anatech said:Hi Joshua_G,
It's warming my heart to see a righteous friend.
Thank you for your goodwill and assistance. Now I know whom to ask technical questions.
- John Curl's Blowtorch preamplifier
