SY said:Just to be clear, by "temperature sensitivity," I'm referring to reliability rather than tempco.
Only an issue if you heat them much above 80 degC. So don't mount them near power transistor heatsinks.
Not an issue for preamplifiers at all.
Glen
andy_c said:I have one of these cards in my bench PC. I plan to use it in the configuration Renardson recommends for distortion measurement, so I hope it works out well.
I hope this isn't the technique that gets him 0.001% THD-20 for that class AB MOSFET amp of his 🙄
Glen
john curl said:I'll stick the Reliable polystyrene caps, at the very minimum.
John, there have been MIL spec NP0 ceramics for ages, so reliability is not a concern with legitimate vendors. Back in the Clinton administration, the COTS (commercial off-the-shelf) initiative was originated. This meant that new contracts going forward did not require MIL spec parts. This was a great cost-saving measure. But prior to that time, for decades, all MIL spec capacitor vendors had to go through "qual" (qualification) for their parts to be put on the QPL (qualified parts list) for the MIL spec in question. This meant all kinds of crazy tests they had to pass.
For me, the data of such tests means far more than anecdotal information from questionable sources. It's not tall tales about submarines or anything like that.
Hi Bratislav,
That was my point, and has been for many years now.
Hi Andy,
Hi John,
-Chris
Edit:
Hi Zap, I have been trying ....
Hi Andy,
The problem with trying to test these parts is that the problems are dynamic by nature. Their impact also varies with the circuit parameters. The very worst place to have a "bad capacitor" is in a high impedance circuit with large voltage swings. The high impedance allows the distortion mechanism to be excited without any ability to swamp it's effect. The large voltage swings exercise the full departure from a linear transfer characteristic as well. By definition, that would be the Vas in an amplifier and any other capacitor in a similar position across a transistor C-B junction. With a lower impedance location, the effect of dielectric non-linearity is very small compared to the total amount of electronics available. High impedance = lower current flow rate = fewer electrons = more of an effect. I know you that you understand these things, but for the benefit of some other members who are learning I drew it out.For some of his tests in which capacitor distortion was easily measurable, he was not able to measure changes in capacitance with voltage. So while conventional distortion measurements have been (rightly IMO) criticized for not relating to audibility, it seems they are very good for "sniffing out" very small nonlinearities.
I also have the same card intended for the same purpose. I haven't set it up yet, could you please give me a link or PM me with this information? I'd really appreciate it.I plan to use it in the configuration Renardson recommends for distortion measurement, so I hope it works out well.
Hi John,
Heck, nothing wrong with that!I'll stick the Reliable polystyrene caps, at the very minimum.
-Chris
Edit:
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Additionally, a 503 Service Temporarily Unavailable error was encountered while trying to use an ErrorDocument to handle the request.
G.Kleinschmidt said:I hope this isn't the technique that gets him 0.001% THD-20 for that class AB MOSFET amp of his 🙄
Well, it's a nulling technique very similar to Bob's "distortion magnifier" - so I hope it works out well. My bench test equipment is quite modest, so any input one way or another on cheap distortion measurement is welcome.
anatech said:Edit:
His site has some funky metering for limiting the data transfer rate. I've found that if you wait an hour and try again it comes back automatically - assuming someone else isn't doing the same thing.
anatech said:When someone trained in any branch of physics begins reading these works of art, their response is generally one of annoyance at best. These individuals typically do not get through the entire article. In fact, many freeze within the first paragraph, then read on as if watching a train wreck in slow motion.
That's funny, man! I am listening to Hugh Masakela's Hope on headphones while reading this, and laughing very hard, but I cannot tell how loud I am laughing. My neighbors probably think I am very weird - and they're right!
Hi Andy,
Why ... thank you sir!
I'm glad you enjoyed it, as was the intent. Please tell me no keyboards were soiled due to excessive mirth. 🙂
Well I hope the technique is valid and works out well. I looked up his website a while ago for distortion measurement info, but stopped reading after I saw this and read that "the distortion is less than 0.001% up to 20kHz".
Glen
Glen
Some of us use tubes in our preamps...
Please, I challenge ANYONE to make cost effective analog electronics that sounds as good or better than what we make in hi end, today.
Maybe it is already being done, I don't know.
I also challenge engineers to make autos either in GB, Canada, or the USA that exceeds the efforts of Mercedes, Porsche, and BMW, at the very least. at very low cost.
Also, let us make a CHEAP auto tire that does everything that is needed in a modern, fast car.
I would love to have a source of cheap, but drinkable Cognac that tastes at least as good as REMY Martin VSOP.
Go for it, fellow engineers.
Hi John,
No one (at least I'm not) saying they can exceed your performance level cheaply. Mind you, with the cost of the casework reduced it should be possible to clone your design at lower cost.
No one has stated that you don't know what you are doing either.
So in that light, why the challenge?
The maintenance cost of a BMW over 5 years is the same as a Honda and not much higher than a Ford Capri. The only difference is that the Ford will be worth zilch and the BMW will still look and handle close to new. That's given good competent service is performed on each. Getting good service tends to be the problem.
Honestly John, why try to compare the more expensive options with the bottom of the barrel options? There is no value in that at all.
I would love to hear one of your Blowtorch preamps some day. That way I could see what all the hub-bub was about.
They cost less in Germany. 😉I also challenge engineers to make autos either in GB, Canada, or the USA that exceeds the efforts of Mercedes, Porsche, and BMW, at the very least. at very low cost.
That will happen in China, just you wait ....Also, let us make a CHEAP auto tire that does everything that is needed in a modern, fast car.
They all do ... after the first glass.I would love to have a source of cheap, but drinkable Cognac that tastes at least as good as REMY Martin VSOP.
Some solid state preamps run hotter than a firecracker!Some of us use tubes in our preamps...
You have to be aware of ambient temperature no matter where you use Polystyrene capacitors.
apassgear said:
Oh yes, at 20 Euros each shure sounds good.
How about some that cost 40 Euros? that would be two times better sound?
Just remember that sometimes quality has nothing to do with price. Price has never been my criteria to buy audio components.
And yes also, "sometimes" they do cost more.
Try and then refer, do not generalize.
for Peter Daniel: caps distortion is worst when they are heavily loaded, that's why the crossover cap type is important, and very audible.
Regarding PSU caps, I have mentioned them. They are not the most important, though.
I thought this was the solid state forum........
Please, please show me a design for a preamp or a power amp that is commercially available that is better than a Parasound in both specifications and sonic quality, at a significantly lower price point. Show me, don't scold me!
Specs are easy to define and compare. But "sonic quality" is a pretty nebulous criterion. Sonic quality as judged by whom? And how?
Has someone related caps sound characteristics to the triboelectric effect between two materials…?
- John Curl's Blowtorch preamplifier
