John Curl's Blowtorch preamplifier
john curl said:
Scott is putting forth DA as a form of non-linear distortion, BUT it is really a form of LINEAR distortion, (as he knows full well, because he helped us measure it, initially, over 25 years ago). Linear distortion is also a major component in what is wrong with resistors, due to their thermal capacitance and tempco. Work it out on a calculator, if you don't believe me.
No please don't misquote me, I agree with Pease DA can be modeled almost completely with a bunch of RC networks completely linear and time invariant. There is no DA distortion.
jlsem said:
Classic Records remasters most of the RCA classical recordings you are probably interested in. SpeakersCorner makes a specialty of remastering Decca SXLs, which are generally better recorded than RCA Living Stereo. They also do Philips High-Fi Stereo re-issues. I don't listen to John Denver and have never heard of Esquivel, although Elvis can be fun from time-to-time.
John
Sorry John I don't mean to be a PITA but I'm interested in the specific performances like Reiner and the CSO as you say aesthetics is everything. Please don't take any offense at my comments.
PH104 said:
Pavel -- The Caddocks which Sigurd mentioned are wonderful but expensive. I would have needed a bank loan to buy 64 of them for my power amps. The Vishay/Dale LVR series are very good and what I am using now. A little over $1 from Mouser. Up to 5 watts they are metal strip as opposed to metal foil and non-magnetic. The terminals are copper. But they are limited in resistance range from 0.005 to 0.25 ohm.
Many years ago we used to submerge the high voltage divider strings for mass spectrometers in a 55 gal barrel of oil and keep them at constant temp.
Thanks for the tip.
PMA said:
This is not any scientific forum and I have not enough time for DIY only. The generator output impedance was more than 100x higher than that of the resistor measured.
I do not need to read about scientific method, as I have enough of scientific publications.
You are a kind of a nit-picker.
PMA,
Anybody can post a curve and say this is such-and-such. Without knowing how, what etc, it doesn't say anything. It is good practise to include your measurement setup etc so that others can judge your results, can reproduce them if they want, and ask for clarification which can also benefit you.
In that sense yes I am nit-picker.
Jan Didden
Sorry PMA but janneman is right to ask for the details, otherwise we have the potential to end up down a blind alley because we have built our knowledge base on uncertain foundations. Especially so when we are dealing with one of the lowest level and most basic, but fundamental elements of a circuit, the humble resistor.
Hopefully someone who has the equipment and the time can do the experiments fror us and publish the detailed setup and results.
Alan
PMA, I agree with you. You are not putting out 'idle speculation'. You are presenting 'informed measurements'. You are an engineer, you have the test equipment and you measured an OBVIOUS difference between two resistors. DUH! Because that is exactly what we should expect, and this has been known since the beginning of electric measurement.
This is why Ayrton and Perry made their attempt to produce wirewound resistors will low inductance 120 years ago, and Tesla did his about 100 years ago.
EVEN with these exotic windings, there still could be some measurable overshoot with low impedances because the Q of the windings is so high, due to the large wire or its equivalent used.
Why do others 'nitpick' unless they have something directly contradicting to contribute? Then we have a chance to 'nitpick' their efforts as well. It is because the 'facts' are not the issue, with questions like these, but subtle ridicule is.
Otoh, if the differences shown are due to some aspect of the test methodology, the conclusions drawn may be incorrect.
What was shown is sufficient to show that under some uniform test condition that the results from two different construction (and slightly different value) resistors was different. It is reasonable to then logically extend that to say that in some instances one may get different performance in an actual circuit from two different construction resistors.
We can not determine which construction is "better" nor what the true nature of the difference is from PMA's post...
_-_-bear
What was shown is sufficient to show that under some uniform test condition that the results from two different construction (and slightly different value) resistors was different. [snip] _-_-bear
It was definitely not. I have no axe to grind with anybody. But what was shown was just a graph with some labels. If anybody expects to be taken serious on that account just because 'we're engineers' (whatever that means), he's not an engineer in my book. He's a tinkerer. Which is OK, but we should know.
Jan Didden
john curl said:
This means that one must have access to a pretty darn good stereo reproduction system. The Met7's (I own 3 pairs, myself) are marginal in making these difference comparisons.
I forgot to mention that I have Sennheiser HD-600 head phones and a pure class A driver for them. Isn't that OK for hearing small things? Frankly they are too revealing and I find something wrong with just about everything through them.
Jan Didden
Nice attack mode, Jan-da-mon...
the fact is that assuming he is not confabulating or faking the results, he did two identical tests where the variable was only the DUT. The rest is self-evident, as I noted.
And have you checked PMA's credentials?
...next case...
_-_-bear
How very interesting!
"...too revealing and I find something wrong with just about everything through them..."
Perhaps this is your big opportunity to try some <gasp> different interconnects going to that headphone amp? Different sources? <gasp>
How about getting some good headphones like some top of the line STAX ESLs?
Imagine how "bad" everything would sound then?? :hot:
_-_-bear
Bear, I suspect the Sennheisers are pretty good. However, I use STAX, myself for really serious stuff, direct driven by class A tube electronics.
I just talked to Jack Bybee about this discussion, and he understood it well. I even mentioned that some put his name here 'in insult' on occasion.
I also mentioned to him about something on the internet called 'SCIENCE FRICTION' a British history of scientific argument and resistance to change. Maxwell's equations were mentioned first and foremost.
What Jack had first contacted me was about the 'Naked Singularity' article in the Feb 'Scientific American' (and you think that we have far out ideas) :boggled:
These guys publish some detailed information on resistors, including a thin film power resistor with a quoted inductance of less than 50nH. Their precision wirewound range is quoted as 3-5 uH by comparison.
Out of interest, in their catalogue they mention for several wire wound types that "they can offer low inductance/reactance versions" so the implication is that wirewounds are NOT non-inductive by default and therefore what we choose to use may make a difference.
http://www.riedon.com/us/index.php?option=com_content&task=view&id=16&Itemid=26
john curl said:
The plots are 'self-explanatory', PMA.
Thanks, John.
Though it is a little bit off topic, I would like to mention that I do have "some" experience with shunts, their construction and measurements - attached is a squirrel cage shunt of 1mOhm, 1MHz BW (with compensation), up to 63kA, for short circuit tests of HV and UHV circuit breakers.
