John Curl's Blowtorch preamplifier
syn08 said:
John,
Thanks for disclosing this. While reverse engineering your CTC BT I've noticed this topology and I was really dissapointed; you could get the same results (and even better!) by using a single +/- very low noise (and output impedance) power supply (like the Jung super regulator) and make sure you use a drive/sense topology, shielding the sense wiring and a symmetrical layout of the gain stages.
This would still require extra wiring but would certainly lower the overall complexity. Of course, this would mean you should use opamps in the power supply 😀
Using such a topology I got in my latest phono stage 75dB unweighted S/N @ 0.5mV, 1KHz input, 64dB gain, and almost -100dB crosstalk. The power supply is in a separate housing and has by itself about 7nV/rtHz noise up to 10MHz. This is of course further killed by cascoding the 4 x JFET input stage, locally filtering the supply, and the opamps PSRR.
While that may provide rock stable voltages to the devices, it does not address the issue of current path control.
I surmise Johns "fix" is probably better than what you are thinking of..
Cheers, John
syn08 said:
What I said has nothing to do with the current path control and magnetic effects, but with the xtalk and multiple power supplies.
Methinks John feel the same way.
It's just so strange to hear everybody talk about moving signals around willy nilly, without worrying about where the current is actually going..the path it takes...
Just because a signal is e-shielded doesn't mean that it does not have an external magnetic field. Just because you put a shield around a coax, that still doesn't guarantee the shield current is equal to and opposite that of the signal..especially when the shield connects to something at both ends...
In the conversion from tubers and high Z..... to zistors with low Z, magnetic field and induction has been a lost child..
Weird..
Most people still believe they can get a 50 plus watt 4 ohm load resistor that is accurate at 10 kilohz...
We got a long way to go...🙁
Cheers, John
john curl said:
Grounding is NOT why we have multiple supplies. Xtalk, and line isolation are the reasons.
From my experience grounding directly affects all of these.
The most sophisticated power supply circuit will not perform well if the ground reference is noisy. All it takes to add noise on your supply reference (or for that matter any gain stage) is a return path, for any of the multiple loops in the circuit, that follows the same path as the supposed quiet reference's. This is where the discussion of unintended paths becomes relevent.
Mike.
Weird..
Cheers, John
I'm not debating the magnetic effects in power amps. God knows, I sweated blood around such issues in the PGP amp.
Ground loops are important for both avoiding magnetic fields (through uncontrolled current paths) and xtalk issues (through sharing finite impedance paths). Of course, they have a common physical root (current flowing paths) but unfortunately IMO they can't always be addressed by the same countermeasures.
Example: you can't avoid current flowing through supply wires, and even if you cancel the magnetic fields by running the return path in parallel, this would help squat for crosstalk issues, 'cause the finite impedance path is still there, shared by the gain stages. It's electrokinetics vs. electrodynamics.
It is not necessary to avoid magnetic fields. Nobody's said that.
What is important is to either eliminate the fields, or figure out how to ignore them...turn the receiver off.
The fact that you haven't gotten into trouble with how you control the ground current path doesn't mean the problem doesn't exist.
It's a question of mind over matter...if you don't mind, it don't matter.
If the crosstalk is a result of mutual inductance, you have several choices. Stop the transmitter, stop the receiver, cancel the fields by summation of opposite, or make the structures orthogonal.
Simply paralleling wires doesn't cancel magnetic fields.
They must have a common integrated current centroid. Either twist the daylights outta them, run coax, multiple twisted pairs, or high aspect ratio stripline. There is no other way to eliminate the external magnetic fields of a wire. Conductive shielding at the low frequencies requires just too much thickness for eddy currents to counter the field.
Cheers, John
jneutron said:
<snip>
Look at a power amp for example..most designers just run the rails willy nilly. I do not.. I will run triax or stripline from the supply to the output stage, and make all efforts to have the output current completely cancel fieldwise within the chassis.. It gets difficult at the pass devices, as it requires either a coaxial ground return path, or running the rail strip directly over the output devices.
I don't need to explain how a 10 amp 5 Khz sine current on a #12 wire that is not near the return current will generate magfield, nor that the amp topology on the input side of the feedback divider is very sensitive to the inductive coupling. Most people don't even understand the merits of a feedthrough capacitor over a standard one..
My preference is to create a chassis which has no stray e/m fields produced. That way, the extraordinary lengths you use are not required. (or at least become less important).
I also deal with the chassis-external parts in the same fashion.
Cheers, John
Can't speak for the others, but I would love to see some images of the amp you are referring to? Would you post some?
_-_-bear
I'll just make one point: In a split +/- supply the return path is not normally center tap ground (only for the charging currents). The loop goes from the positive side to the negative side. The ground is only a zero reference for the signal.
The simplicity of this statement changes as the power levels goes up, but the concept of shielding the power wires needs to be thought through if viewed in this light.
Oh my...
After reading this thread onwards it seems there is no mention of boxers and debaters trying to smote each other and or how to validate their actions. This is good human progress! I cheer!
So, correct me if I am wrong, the Blow Torch preamp circuit is primarily the same circuit that John developed for the Grateful Dead thingy? And this thread is all about that, (no, I know there is so much more, but I’m trying to find the reduced syrup here). Yes? No?
No folks I’m not kidding, I’ve read this thing up and down I just don’t get it. Is this a long extension of a review from Stereo Review 1989 or is there something going on here that I should be learning and or missing? By the way, I think JC has way more to offer in some other threads here on DIY Audio. I truly love the dude’s way with capacitors!
One more time, I’m not putting nothing or nobody down here but this thread seems to be lacking meat and potatoes. I hate being vague, you all know I’m lying when I write that, but is this some kind of esoterical discussing or are yee all discussing the ins and outs of THE Blow Torch? Shouldn’t a well rounded talk start with some kind of schematic?
Sorry for being a jerk but please help me out, if you can. I walk away now if I’m beating a dead hose.
Happy DIYing!!!!!!!!!!!!
No, this is not about the Grateful Dead. There a plenty of schematics posted within this thread for someone to make a virtual 'Blowtorch' However, the specific design is NOT for novice amateurs, as it is just too hard to do right. However, the PRINCIPLES of successful audio design are 'fleshed-out' here far more than usual. It is these 'principles' that I think more important to present than a specific schematic that only a very small number of people could make successfully, in reality.
It is possible, with effort, to make the HCA-3500 almost as good as a JC-1. The actual schematics are almost identical. However, there are dozens of details, that make the difference. This involves: feedback resistors, bypass caps, using high speed diodes instead of normal power diodes, bypassing the Surgistor on the power supply line, transformer polarity, and others that I can't think of at the moment.
bear said:
Can't speak for the others, but I would love to see some images of the amp you are referring to? Would you post some? _-_-bear
That I will be unable to do.
I've built two personal amps using the best grounding and e/m layout I could figure out, but didn't have a digi cam to take pics during build. I no longer own the amps, but gave them away to better homes...my basement is too full...
Current work is unfortunately, not allowed for public consumption. IP stuff..not mine, but that of others...
However, that said..there is nothing to prevent the next build with pics, now is there? I've been gathering the parts for a four channel PA setup, here's a partial list of materials..sorry my cam is home today...got the box right here..I can take a pic tomorrow though...
2 plitron #1614 toroids, 225 VA apiece. (I'll rewind the secondaries to get the supply voltage I want plus 12 vdc for the fan.
2 L4780TA chips, dual 60w chips..
1 suitcase, aluminum...to make the thing really portable
2 neutrik 4 pole outs.
4 panny 50 volt 22000 uf caps
1 cpu fan/heatsink assembly.
2 GBU8K bridges.
A roll of 5 mil thick copper sheet, leftover from the home reno. I'm tossed between making the 3 layer supply feed out of the foil with 3 mil sheet insulation....or half inch wide flat copper braids. The foil design is gonna be sexier..I think I'll be able to forgoe bypass caps at the chips cause the foil inductance is gonna be sub nanohenries. But that'll be fun to try...
But I'm not sure this thread is the place for it..perhaps a new one?
Badge said:
I second that. We anxiously await the pictures and schematic so we can marvel at your work😉
I hate to let you down..the schematics for personal use were nothing to write home about. One was a tigersaurus 250 repackaged, the other was a two chip amp using LM 3876T's. It was only the routing and wire layout that was different and new..
The only thing about the tiger that was in any way interesting was it's lack of noise (externally generated) and hum. I always kept the bias turned as low as possible, so the amp was unuseable for critical listening, it was only good for high power PA. (you know, when pigs fly).. At the time, it was used five feet from a 250 kilovolt vandygraf and 10 feet from a toro700 leafblower motor..
In a split supply feeding a B topology poweramp, there should not be current from rail to rail. When the pos rail is feeding current to the load, the load is returning the current through the ground. Then neg current is through the other rail but still returns through the ground.
Both rails have to be very intimate with the ground return. I don't ground the load terminal at the binding post or neutrik, but bring that current back to star..
An H bridge works as you say, but I'm not sophisticated enough to deal with H's yet.
Cheers, John
ps.. I purchased 2 mp3 usb sticks as music source, so I''ll probably have to also put 5 volts or 1.5 volts in..and I'm seriously thinking of building the mike pre/mixer from scratch, as I am scared of relying on the Behringer UB-502 or the UB-802. They were too inexpensive to make me wanna rely on them..gut feeling, no experience with failures to date, three years now..
Cheers, John
Hi John,
I was discussing preamp levels, you'll note my comment about things changing as the power levels went up. Actually as I think back on it I should have picked up on your comments being amp based.
In a preamp the majority of the currents are bias related and flow from neg to pos, the signal currents are negligable.
In my amps I do as you mention as far as the speaker return, back to the power supply reference. There are no grounds used in the driver/output or voltage amp stages so there would be no return currents to follow the supply connections. There is a ground for the input and the +/- regulators for the servo supply; these returns mirror the supply feed as you suggest.
I believe we are saying similar things only with different experience and points of view.
Regards, Mike.
