John Curl's Blowtorch preamplifier
Wire with gain.............Steve?
Damm Steve you beat me to it.....................😀
How about this?
Jam
Pardon my ignorance, but when trying to control a circuit, with respects to stabilizing AC modulation, has anyone ever use a dual wound transformer, as similar to an infinite slope crossover, but use the opposing transformer winding in a opposing fashion..via a transistor load -with a mirrored signal (on that 'side' of the transformer). This would clear the transistor from the signal path and leave the transformer as the only effective device in the path. I'm not a circuit guy, I'm just musing a bit. Ah, I'm sure it's done in some place, somewhere. I realize that's a lot like tube circuitry, but I mean it in a slightly different way.
I'm not quite following you here. Could you scribble a simple schematic to illustrate?
se
Using the modulation in the one side of the transformer as the control point of a servo, via actively driving the other side with a mirrored signal. Something like that. If you think about it, you can actually create a fully modulated pathway via transistor controlled transformers,and never have a transistor in the path at all,other than base junctions for monitoring the given signal point.. You just have to start with a pretty chunky signal. Ah, just thinking out loud.
It's the same thinking that tells me that one can have a phase perfect passive crossover for loudspeakers, but you have to be willing to throw away a minimum of half your power for crowbaring the signal in the phase domain. How much energy is left to control the woofer and like is debatable, but it can be done. It just goes against what people normally think. Active preamp signals are likely easier to work with, in that single respect, where the dynamic stability of loudspeakers is a nightmare. I dunno. Just musing out loud.
But if you use transistor controlled transformers in place of transistors themselves, you get a circuit where no direct active component is in there at all. Surely there is benefit to that. However different to implement and figure out. Depending on implementation, it would also be kind of hard to pass DC. I mean the transformer is stacked on top of the transistor, in effect, but the transistor becomes absent with regards to a notable part of it's sonic additions to the whole shebang. Maybe. You'd have to try it.
Could be an interesting result. Might be fun to go through the exercise.
john curl said:
Some people will do things the hard way, when IC's do it very well, cheaply, and with a small footprint.
Years ago when I was less than 5ft tall our family had a really smart Blue Heeler / Labrador cross-called Susy. I took her for a walk in the park one day and asked “what’s that up in the tree?”.
She astutely replied “BARK! BARK!”.
It's true :nod:
Well, if the transistor's controlling the transformer, then the transistor is ultimately still there.
A transformer by the way can give you voltage gain without any transistors at all.
se
