scott wurcer said:
50's? not many, maybe in the Urals 🙂. My father worked at the mines in 1977 for 6mo. as a consultant. He had lots of good stories, 24/7 KGB "friend" etc.
There were no power at all in some far Russian villages. I mean DC power in USA that was used, that's why there were no transformers in American receivers. Bastard Lenin started from building of hydro power stations to supply AC, so transformers could not be eliminated.
Hmmm... your father was very top level consultant to have a personal professional bodyguard. 😀
Is 35Z4 OK with you? It has been 40 years since I have seen or used one.
12L6? I have used a 6L6 since 1958, and my Gibson guitar amp was made in 1938 that used them.
john curl said:Is 35Z4 OK with you? It has been 40 years since I have seen or used one.
It started from 2A7, 58, 55, 59, and 80.
In later versions more modern tubes were used, and 80 was replaced by 25Z5.
6L6 and 12(50)L6 are very different tubes. I use 12L6 with 170V B+, 6L6 wants more.
john curl said:Don't you mean: 25L6.
25L6 is the same as 12L6 and 50L6, heaters are different only.
I understand, but it is important to differentiate it from the 6L6, because of the very different characteristics. My 'RCA Receiving Tube Manual' does not include the 12L6, so I could not separate which tube characteristic you were associated with.
john curl said:I understand, but it is important to differentiate it from the 6L6, because of the very different characteristics. My 'RCA Receiving Tube Manual' does not include the 12L6, so I could not separate which tube characteristic you were associated with.
12L6 are nice tubes; on IRFPG50 steroids they give me 300W per pair of long term sinusoidal power, through cheap compact toroids.
I hope that Scott will contact Dick Sequerra to get his questions answered. It would really, really, help to get things clarified. I don't like being 'doubted', especially when a mutual friend can clear things up.
DC use in the US was more interesting than I thought. The history of distribution of power reads a lot like the roll out of the internet in the US. In any case it seems the villages you are referring to are Boston and New York. Both burdened with supporting early Edison DC customers. They were finally cut off in the late 1990's. The rest of the US used AC from early on. In rural farms without grid connections you would find DC from the windmill or batteries. The All American 5 was made in the US through the 60's and very few customers needed it for DC power by then.Wavebourn said:
The All American 5 had no transformer because of the cost. GE (a major manufacturer of All American 5 radios) had a history in consumer goods that resembles the current cost down story in China. Except employees were rewarded with real cash to reduce cost in a product.
AC vs DC
Rural Electrification
AC vs DC
Sorry. I knew about Edison's fight against AC, but I did not know about Boston and New York. I did not want to call them villages intentionally.
http://home.netcom.com/~wa2ise/radios/aa5h.html
Well documented, 1Audio, the only time I ever saw 120V DC from an outlet was a New York Hotel in 1965. However, at Underwriters Labs (UL) we had our own massive DC generator and standing coils as big as a car that we put in series with the DC we generated, and then I got to burn up AC-DC plugs by drawing an arc up to several inches. It was fun, when I was 20.
Given how important power is for our obsession with reproduced music its surprising how little most of us know about it or its history. I now know why we have "110" volt power in the US. Its from the realities of carbon filament bulbs in the 1880's. A superb example of a solution for an old problem burdening the future.
Hi John,
I don't think high speed diodes are your friend. The same goes for massive amounts of capacitance. However, where Nelson Pass uses them, they do help. A different situation completely from the average topology.
Hi André, Franklin,
I can only advise you all to go back to basics in electronics and apply what you know. The concepts are not difficult but the physical reality may be where the trick is.
Each and every situation is different, either due to the circuit type and / or how it's laid out. For example, when you are designing your supply, consider what is easier to filter out. Is it easier to get rid of 120 Hz (100 Hz) components or a series of harmonics throughout the audio band? Design for things like that while considering the supply currents and how much they vary. If you are looking at a low current supply, then some series resistance will go a long way to reducing the peak charging currents into your capacitors. Also, is there an actual need to huge amounts of capacitance, or are they going to be installed because the current fashion dictates that you "need" that much?
Designing for low noise power supplies requires that you understand what you actually need from that supply in terms of voltage, current and noise. That means you have to think for yourself and ignore what the current fad is. One great source for ideas is older, well made and respected test equipment. Look at the schematics and layout of things like HP / Agilent, Tektronix, Audio Precision and similar companies. You will also notice that the better supplies may take RF principles into account. Then, look at how they actually laid out the circuits. You will see them inside their own compartments, shielded from everything else. Feed-through capacitors will be another thing you should begin to notice as well. Learn from those previous masters - they were right for one.
Finally, look at your circuit design and layout. It's up to you to eliminate or reduce places where power supply noise may creep in. Pay particular attention to your ground wires. Treat signal grounds as if they were actual signal carrying conductors - because they are.
There are some pretty thick books on this subject, and I am not nearly as knowledgeable as some people around here, or those authors. All I really have to guide me is common sense and past experience. I do think that it is these things coupled with an understanding of electronics that will really help to get you where you want to go. This is also why I was surprised when asked how to accomplish this goal.
-Chris
Hi André, Franklin,
-Chris
Hi Demian,
Don't forget that the frequency used to be 25 Hz. They probably used other frequencies as well here and there.
On farms, a lot of livestock were shocked - literally. The earth is the actual return for our power grids.
-Chris
-Chris
It is like in South Africa I used GSM cellphone. They had nothing but GSM. Coming here I was surprised how powerful may be a legacy. Also, I see audio power amps made as typical opamps, almost all of them... The same story repeats.
anatech said:Hi Demian,
-Chris
I had read that. There are a few old large steel mills that still run on 25Hz. Talk about heavy iron!! And Japan is 50 Hz on one side of the island and 60 Hz on the other. Imagine making a turntable or a tape recorder for that market.
100V.
anatech said:Each and every situation is different, either due to the circuit type and / or how it's laid out. For example, when you are designing your supply, consider what is easier to filter out. Is it easier to get rid of 120 Hz (100 Hz) components or a series of harmonics throughout the audio band? Design for things like that while considering the supply currents and how much they vary. If you are looking at a low current supply, then some series resistance will go a long way to reducing the peak charging currents into your capacitors. Also, is there an actual need to huge amounts of capacitance, or are they going to be installed because the current fashion dictates that you "need" that much?
-Chris
Chris, I agree with you on low power equipment it is possible to build power supplies that will not show power cable differences, with high power amplifiers it may be difficult and/or expensive to do without compromising sound quality. Most of the commercial hi-fi equipment that I know of benefit from a good power cord however.
Thanks for your reply.
André
Anatech, you are concluding about my designs outside your knowledge level, and I don't think that is a good thing. Please don't tell me about my using hi speed, fast recovery diodes, if you have not evaluated them in MY audio equipment. I work long and hard to find better ways of doing things, and have done so for decades. I only care about what works, and diodes can be measured to show their problems. Thank goodness, because there is so little in hi end audio that is so easy to measure. Personally, I think that vacuum tube rectifiers are the best.
- John Curl's Blowtorch preamplifier
