Stinius, exactly. Nothing there about political correctness or peer pressure or engineering boundaries or any of those other misrepresentations. Just a simple statement of reality- a properly controlled test would be necessary for me to make a fact-claim. Anecdote is worthless, no matter who the source.
JPV said:
You are correct in asking for more details. Every EMC problem is always specific although there are some generic approaches in solving the problems.
This is a classical problem of ground loop coupling. The ground system is there to bring back the currents to the potential sources that generated them. These will create voltage drops in the ground system. If a voltage drop created by another current is in serie with the input we have coupling. It is the case here if the load is connected to power ground.
But it is not the end. The board ground can be separated between low current signal ground and high current signal ground( the output transistors and on board large capacitor).
It is sometimes good to keep the two grounds separated by a resistor to avoid coupling generated by the large output currents.
It is interesting to hear, like PMA has done, some aural experience, where this trick has shown to be usefull. Or perhaps understand that it is not very usefull, or that it can be wrong in some topologies.
The same for the problematic af ground loops created because of the safety ground. Which kind of ground breaker is the best in the presence of hum in the ground and in the presence of RFI.
The same for common mode noise created by different grounding.
Do we have a different effect with a serie or shunt feedback topology at the input? This from an aural point of view.
These effects are real and can cause different aural experiences IMHO.
JPV
Another related topic is the connection of balanced sources to unbalanced inputs. Balanced to balanced is easy: the two signal wires carry the signal, and the (pin 1) screen makes sure that the chassis of the two pieces of equipment are at similar potential. Then, when the lines and i/o impedances are truly balanced 1) , all noise and interference on the interlink is identical on each signal line and the differential receiver cancels that noise etc.
But if you go to unbalanced, one of the signal lines is connected to the screen at the receiver end, and that combo is connected to *something-earth* at the receiver. Chassis? signal gnd? power gnd? What's your strategy in this?
Jan Didden
1) {I take it as a given in this forum that people know that balanced lines means balanced wrt impedances, and that it has nothing to do with the balance or not of the signals on the line, which has no inpact whatsoever on the balanced line's ability to let the receiver cancel the noise, hum and buzz.}
In this area, I have to make my position clear. I would LOVE to have either a COMPLETE SET of measurements that told me whether something will sound just about perfect, AND a PERFECT way of listening back, so that I can get direct feedback from listening differences, and everyone would believe me, AND I could rely on it, myself, 100%.
Unfortunately, this just doesn't seem to be possible at the moment.
ABX or most other DB tests, tend to obscure differences. I can't operate within their limited range and sensitivity.
Measurements are getting better, BUT still lack many of the dimensional qualities mentioned to me by Richard Heyser 40 years ago. Perhaps, when digital becomes virtually 'perfect', then we can use digitally based equipment to do PERFECT differential comparisons of real music, and then sort out the differences. So far, only half-baked solutions are offered, at least to me.
I will still have to trust in myself, and my trusted associates, that we are not fooling ourselves when comparing design approaches, in amp, preamp and EVEN wire design. I don't have any other way of moving forward, and forward I have moved, since this ABX, DB controversy started 30 years ago.
John, have you had a chance to look at Audio Diffmaker?
For instrance, you can listen to tracks played through a good quality film cap and the same track through a ceramic one, and listen to the difference.
Jan Didden
Jan Didden
john curl said:Not good enough, Jan.
You could do the Listener Challenge . Good chance to establish superior listening capabilities once and for all. A golden opportunity!
I tried at the AES convention presentation. I couldn'd figure out which was which.
Jan Didden
Not good enough, Jan. I make my living by HEARING and MEASURING differences, not being shown that I 'can't' tell any differences in a specific set-up.
Until we get to at least SACD level, and perhaps more, we will not have adequate measuring equipment. I have debated with the designer of this latest differential comparison system in the past, already.
john curl said:Not good enough, Jan. I make my living by HEARING and MEASURING differences, not being shown that I 'can't' tell any differences in a specific set-up.
Nobody want to show anything. We have two tracks with clearly measurable differences, and clearly audible differences. We also know what the 'contamination' is that is in one of them. We know, can measure and can hear the 'contamination'. The task is just to tell which of the two is the contaminated one.
And remember: we can clearly hear that contamination, and we can clearly measure it.
So, don't give us that 'not good enough' bull.
Jan Didden
Jan Didden
Suppose differences will be shown between 2 capacitors, or 2 wires, etc. It will not tell which one will sound better.
What is sound and how would you describe a better sound?
Cheers
Stinius
I'm sorry, but I have to keep my standards very high.
About 35 years ago, (I know, I know) we tried this very test with a 50KHz clock and 10bits with a PDP11-035 mini-computer. We found nothing in electronics for the most part. John Meyer, working with me on this testing, became 'convinced' that electronics didn't count, at this time, because it was so easy to compare differences in acoustical devices. He is still convinced, today, that I am 'way over the top'. So be it.
Today, I can do 13 bits and a 256KHz clock rate with a measurement precision of .001dB. Is that good enough? I don't think so.
However, 24 bits and 500KHz would get me interested.
Think again. A track of a classical choir with a sousa band mixed in is 'better' than the original?
Jan Didden
john curl said:I'm sorry, but I have to keep my standards very high.
Yeah yeah. It's not really fair to ask you to take this test. Too much in the balance.
Have a great evening, John.
Jan Didden
I have used a lot of different Meyer Sound system and some of them are quite nice, but talking about systems that are based on more or less the same idea I prefer D&B from Germany, I personally think that they sound a lot better.
Cheers
Stinius
Jan Didden
Jan
Don’t expect that any of the GEB members will take this test, just forget it.
I think the test is very interesting.
Cheers
Stinius
Cheers
Stinius
Sound is what people usually hear. Better or worse is subjective, it's how I describe it.
This is generally speaking. When I hear certain differences, sometimes I can describe the differences.
Jan Didden
This isn't likely to be the audible difference between 2 capacitors, or 2 wires.
- John Curl's Blowtorch preamplifier
