John Curl's Blowtorch preamplifier part IV
But is it really that?
I understood it more as a general critic of the system favouring the "publish or perish" mantra, that one is forced to follow to get additional financial support and to get the promotion within the university; it seems to lead to kind of inflation of publications resulting from an experiment or a series of experiments.
:up:
-RNM
Here, the only way for scientists to get promotions is to publish. Specific quantities of papers per year.
I can see that as a reason to favor quantity over quality.
The engineering disciplines here on the other hand, tend to favor quality and exceptional performance over writing papers.
A scientist or physicist here who is an exceptional performer doing great things that nobody else can, will get nowhere if they don't have the number of papers published to satisfy requirements.
I do not envy them. The system seems geared towards having scientists with no practical experience, and engineers with no high level theory.
jn
My experience, exactly. I dont have a hatred for Scott or others here for any of their real knowledge. What ever that might be. If it isnt in my own sphere of knowledge, I am sceptical what is told here. Frankly, some of it just isnt very convincing.
At LLNL EE and ME are there to support Physics. But, EE also has their own Ivory Tower - Bldg 131, second floor. between project jobs, I was asked if I would like to work with EE doing research who needed notes and data put into a paper for publication. Or at least roughed out for them. I went and was interviewed. I said it would take me a few months to be able to catch up and understand enough to contribute. That was too long. The pressure to publish was so high, the EE needed to publish but that takes so much time away from his research. What a problem....
-Richard
This reminds me of philosophers debating on angels on the head of a pin.
OK. I'll run some tests on the Quad this week.
1) impedance vs frequency both magnitude and phase at different levels at different line voltages. This is pretty straightforward and easy.
2) maybe acoustic measurements. I don't have a good space for them but if 500 Hz up I may get useable results.
As I remember the Quad transformers are pretty sophisticated. I think they are cut cores. The lams are pretty thin. The ratio is quite high and the secondary is pretty fine wire. Two transformers are used so the ratio required is halved. I'll measure the secondary voltages as well. Finally another use for the two P6013 probes.
That is a great question. You cannot totally discount what people tell can hear. So, its up to how you qualify the experience. Test and measure, and compare. I often use the test of how many others say they hear the same things/describe it the same way by a large number of people in many cultures and systems over time. Then it has a high probability of being true (fact).
Not much different from pharma results. It takes a huge population using a drug to know if it really works or not. Even though a few samplings/tests showed it was working for the few tested ... positive.... However, a larger number of population may show same or different results.
So, in this method, it is the majority outcome/experience and may ignore the few who get opposite results which are also in fact consistent and true for them - but we have no way to know for certain.
Pharma uses double blind tests, something you don't do.
Welcome to Richard's world of doublespeak. Are you going to chase the latest flock of wild geese he's let loose?
His analysis shows a clear lateral dependence of charge movement with excitation, I do not recall if he evaluated that vs frequency, above 1Khz no charge movement.
Yes he did, no charge movement above 1Khz.
I consider RM and his other mention as capable of discerning the difference between amplitude only variation, and some kind of frequency response variation.
His latest comment tells another story.
As to the 20Khz peak, how is the transformer made? do we have any details on materials and construction? I would ask:
1. is it laminations, and if so, how thick?
2. at 20Khz, they better have used litz. Rs goes nuts at these frequencies when wound into coil form for flux enhancement.
3. Has anybody performed a really good measurement of the transformer? in particular, measurement of LS/Rs of the windings independently no load?
4. Whenever I measure any hf litz constructions, I have to be very careful as the test frequency goes over 5Khz, as the interwinding capacitance can play interesting tricks at the higher registers, resonance being one of them.
I don’t know of any public documents describing the transformer, anybody ??
It cannot yet be discounted that the 20Khz peak is not a physical charge displacement mechanism caused by an interplay between the lateral sheet resistance and incremental sheet capacitance within the system. Assuming it is an inductance may not be accurate.
May be, but I give a series inductance by far the highest probability.
I would recommend three approaches.
First, direct measurement of the polar plot of an ESL over a span of DC bias, perhaps 70% to 100% bias.
Second, a thorough measurement of the transformer circuit driving the system.
Third, a set of impedance plots exactly as you showed, but at bias voltages from 0 to 100 %, perhaps every 20%.
If there is an indication that the 20Khz peak is dependent on the bias voltage, that would be a strong indication that the system is not behaving linearly, but is somehow dependent on charge value. (edit: one would also have to consider the time delay parameters of the rings and their drive as well). That would give you the start of a really interesting paper.
jn
In total this could easily be a month work, nice for a graduating student but a bit too much for me.
But starting with an impedance curve for various levels and various HV voltages would already reveal quite a lot.
Same can be done for a 1 meter distance recording of the sound on the speakers axis when the impedance curves shows dependencies on HV.
That’s as far as I will go.
I also have balanced cables to compare as I promised Bill. 😀😀
Hans
I've worked cores from 500 micron to 15 micron lamination thickness. The 15 micron material I used for a 20Khz transformer almost perfect for ESL's, as output voltage was in the kilovolts, and I had to transfer 1500 watts. But man, the edges of that foil is just deadly.
If any of the windings get close to the cut, there will be significant excess dissipation there, as flux lines bunch, which is toast for the copper of the windings. A significant disadvantage for gapped cores.
I'd probably worry about 1khz up. Really accurate measure should not be justified, as if they could hear it (kitchen or otherwise), it should show up in the measurements easily.
jn
Hi Demian,
While I was still typing you published your posting suggesting the same measurements as I proposed.
It would be nice if we could compare results.
Hans
I try to avoid that;
Try..., yeah, that's the keyword. Nobody can stop you from trying.
as I've noticed that you in the past in your responses quite often confused facts and opinions (means that you've denoted facts as opinion) I have to asked if you could quote some examples?
As you've noticed..., yeah, that's the crux of the matter, isn't it. It's also known as your opinion.
Thats very true. Does not change the fact that their results do not often pan out in the field when a lot more people use the drug..... often not DB data btw (Dr and patient opinions). The dbt pharma used to get the OK to sell, often turns out to have different results than their dbt indicated when subjected to larger size over longer time over many cultures.
DBt in audio listening is just like that.
THx-RNMarsh
Please reduce the bias Z to simulate leakage and test also.
Look at the top HF region.... ESL are known for their fast Tr and dont sound dull. See if you get same heavily rolled off HF as Stereophile shows. Which would sound dull.
I was wondering if their rolled off Hf end was due to low HV or leakage because of what i measured at our friend, R.Lees.
A common thread is that R.Lees and myself and here in Bangkok all are near the ocean with high humidity. Since having them in bangkok, the QUAD repair people here say cant use QUADs in high humidity. Seems to be a well known problem with QUADs ?? At least over here.
THx-RNMarsh
Thats very true.
Double blind tests, something you don't do, is? Got it.
Does not change the fact that their results do not often pan out in the field when a lot more people use the drug..... often not DB data btw. The dbt pharma used to get the OK to sell, often turns out to have different results than their dbt indicated when subjected to larger size over longer time over many cultures.
Which medicine can you cite as an example of that?
Which listening test result can you cite as an example of that?
Hmmm The Aircond has a DRY mode for this high humidity environment... mildew etal. Dry out the QUAD and room air and retest.
-RNM
I lived in Asia for 10 years (Japan, Taiwan and China) - the humidity thing in Japan and Taiwan was brutal. First few days in Japan (August) I thought I was being smart by opening the windows, but soon learnt that was a no-no. The carpets actually felt 'wet' that's how humid it was. Even then, we ended up with those buckets with crystals in them that soak up the moisture and turn to liquid in every cupboard.
You wont really get a cool season in Bangkok - unlike Tokyo and Taiwan - so it will be a year round battle I'm afraid.
Small wonder the Quads wont work in that environment! Best thing is to leave the sound room aircon on 'dry air' permanently!
His analysis is purely membrane deflection caused radial movement of charge due to membrane curvature in an e-field that is straight and normal to the film. That in itself will be frequency limiting as the deflection falls with frequency.
On the other hand, an ESL with rings by design, applies non normal lateral e fields to the film via ring delays. Obviously well outside the scope of his paper. But I can see that segmentation delay causing significantly higher charge movement simply due to angular field generation.
To wit..if the hv bias is infinite, the stator efields at the film between rings will be perfectly normal to the film surface. With no bias field, the inter ring spaces will have significant lateral e-field component, and as bias climbs from zero, the vector summation will have less and less relative lateral field.
How it plays with frequency would not be an easy calculation, I suspect polar response would be an easier way to see it.
Perhaps. But I would have suspected the peak to be considered at initial design, so find it interesting. Measurement of the transformer to me is by far the easiest to do, but I always remain wary of the "if all you have is a hammer, everything is a nail".
jn
