John Curl's Blowtorch preamplifier part III
To be fair, Two Flames is more refined, meaning that for most people it is the preferred one. I'm just trying to see deeper 'between the lines' and speculate that if the music accuracy is critical I will prefer 'Test Dept'.
Ok, perhaps your definition of 'accuracy' is different to mine, ie I prefer Two Flames loopback recording because I find the clarity, dynamics, focussing and stability to be better than the 'Test Dept' original.
Thanks for your follow up though.
I have told you before, that the best thing you can get is similar to bybee, and JC has just mentioned that he didn't use it for his critical audio input, only for TV, and that's what I have guessed.
I reckon what I already have is better than BQP and useful in all the above applications, and the more in use the better the system gets.
Also, I'm sure that if our system is so bad, we can benefit more from your effort. But if our system is good already, it can be a drawback, depends on taste and sensitivity to phase.
The worse the system the better the subjective improvement and so far I have not found Goop to be any drawback, in systems ranging from home hi-fi through hi-end($ 200k+) through to stadium systems ($millions+) I have found it to be of benefit always.
BTW, I don't have gamelan recordings. Only CDs. But I'm familiar with this music live. On my wedding day we have this gamelan music, which is a tradition for Javanese people (my wife).
I meant CD, tell me a title or performers and I might be able to find it.
Dan.
Hi Bob and Johnego (and everybody else), here are the CD quality Test Dept files -
Dan.
I would be glad to participate as long as the files are not identified and something like groups of 4 with it unknown if 1, 2, 3 of either is included. Unfortunately there is no way to eliminate the data examination cheat but it could be less obvious than the last time.
More like PMA's tests where nothing is disclosed until a few folks try.
So basically you was marking a post, that pointed/reminded to the (at least afaik) single/lonely piece of evidence, as lacking evidence? 🙂
Probably 🙂 It seemed as though we couldn't be sure it even existed 😉
Some people refer to "subjective accuracy" as if it's a thing.
Referring to someone as "Oriental Japanese" is trite and unaware. Did you ever see What's Up, Tiger Lily by Woody Allen.
Scott,
With all due respect, you are assuming I am white. If I was black you would not dare say such things. If I was Asian I would more than likely be bemused. As my racial identity and ethnic background is none of your concern, I reject your judgment upon me.
tapestryofsound
That’s what was meant by my ‘challenge’ ......if you could pm me my own files so as not to be corrupted by others opinions I’ll pm you back my results then you can post the files for everyone, then reveal mine?
But I’m definately interested in dans comparison of a good file to start with.
Won’t be able to give it time until this evening or tomorrow AM though.
Edit.....I have no way to measure the data so no cheating here!
Edit 2..... it must be music and not the Christmas c*** song! In other words ‘normal’ music!
Hmmm I fear my definition of normal is not yours and Scott is waaaay out there. I guess a male voice choir in a giant water tank is off limits?
YouTube deep listening, which I love
Subterranean sounds: how an empty water tank shaped Jherek Bischoff’s album 'Cistern' 45 second echo!
YouTube Pauline Oliveros in the same tank
Don't see what's abnormal about this 🙂
Hi Scott, this current pair of files is not a challenge as such, it is intended to be educational and illustrate what subjective changes occur when analog signal is routed through DAC/CABLE/ADC process, and in this case illustrate that this 'remastering' can be preferable to the original.
I can turn this into a more formal test by changing ONE parameter only (the loopback cable) and without files identifications we can see what preferences emerge, but accompanying justifying descriptions would be required to complete the value of the findings. By all means please go ahead and see if you are able to discriminate the two new CD quality Test Dept recordings (sighted is fine), if you are able to do so I can shift that to blind testing by renaming the two files and if you can pass that we can move to comparing three or more files.
In the first case you stated the files 'are the same' which is now known to be a subjective test false negative, but why ?.....not paying attention, in a bad mood at me, preconceived notions, negative expectation bias, your system is not good enough....or what ?, There is some reason that you were excluded from being reliable test subject, perhaps this CD quality test may change your eligibility, or not ?. Either way I thank you and everybody who participates, this is all in the name of advancement of audio recording and reproduction (and other stuff), Goop is serious advance in my opinion and with the right help this understanding and knowledge deserves to be universal and I can't hope to make it a household name on my own, all helps will be rewarded.
IMO it's a real pity that the mere mention of the mysterious Large 'BQP' causes such emotional reaction, derision and hysteria from those who have not experienced this device. I could draw a parallel regarding other subjects such as UFOs.......there are all kinds of accounts of sightings from credible witnesses but historically the media and authorities and militaries have poured scorn and derision and discredit on these witnesses, and just why would that be ?......I will leave this as a rhetorical question.
There are a bunch of good minds here, some strictly institutionally 'educated' and others who come from different knowledge bases, surely between us all we ought to be able to reverse engineer and explain the construction and operation of Large BQP ?. None of us are getting any younger and all the ego based nonsense that fouls this forum is just wasting everybody's time, this thread was formed in honour of JC in order that good minds could share knowledge and experiences and collaborate to improve the audio art, at least for the DIYer. The timewasters/fudkwits who are not interested in audio advancement please collect in a different thread and allow those who are interested in audio advancement to do so.
Dan.
Dan has to do this not me and pick any music you want, maybe he could take some Uncle Bunt Stephens and make it sound like it was recorded yesterday.
YouTube
The music posts are an antidote to some of the "audiophile" drivel. BTW there are numerous free downloads that will let one examine the data, and I wish you would not call it "measurement" because that implies measurement vs. ears. A digital file is data there is no hidden information.
.....A constant insult to the growth of knowledge through the ages.
I showed a friend this Moon Landings Faked video the other day and he still wanted to argue his case and that we weren't there as witnesses,.....which is true.
I told him I saw it on tv at Mrs Smith's house, over the road from school but that just encoraged his protests....oh well.
I showed a friend this Moon Landings Faked video the other day and he still wanted to argue his case and that we weren't there as witnesses,.....which is true. oh well.
At least the aliens like Hello Kitty too. Oh BTW hams intercepted some of the mission radio transmissions with highly directional dish antennas, this is a fact.
......maybe he could take some Uncle Bunt Stephens and make it sound like it was recorded yesterday.
Challenge accepted.....I can make it sound like it was remastered today, will that do ?.
00 - Uncle Bunt - Youtube Grab.wav
01 - Uncle Bunt - x1.wav
02 - Uncle Bunt - x2.wav
03 - Uncle Bunt - x3.wav
00 - ....wav is Youtube Grab.
01 - ....wav is YT Grab file looped, ie 2nd gen.
02 - ....wav is 01 file looped, ie 3rd gen.
03 - ....wav is 02 file looped, ie 4th gen.
More generations gets more of the shellac sound out of the mix, please enjoy.
Dan.
This (with a little editing) would make a good opening post of a dedicated thread
A dedicated thread would be a good idea for this kind of exploration/informal testing but I would need to have edit permissions to delete the garbage posts that do not belong, posts from the likes of the fudkwits and ABXers who can't read first posts and insist on divisive and derisive behaviour.
Who is the moderator on this thread......I have posted a request to contact me more than once via the post complaints button and no response which I think is very poor response, not even acknowledgement that the message has been received and will be attended to.
Dan.
Sounds like you want your own forum where you are king and in complete control. You will not get that here. And I welcome that fact.
Dan.
Dan,
I have downloaded the files into Twisted Wave on my iPad for a proper listening session later. I have no idea or any expectations of what I should or could be hearing, which is all to the good.
When you say ‘looped’ do you mean ‘gooped’? ...... might have been an auto spell typo. 🙂
tapestryofsound
