John Curl's Blowtorch preamplifier part III
Does a speaker output sinewaves? Does any auditory objects? What impinges on the eardrum is not a sinewave. Confusing a useful model with reality, as DF96 did & calling it a fact is blatantly incorrect
Yes, loudspeakers can output sine waves- listen to Kraftwerk.
Yes, auditory objects can output sine waves - listen to Tibetan bells.
Yes, the ear can hear a sine wave.
You are confusing a sine wave with a pressure wave - basic physics.
You might want to listen to DF96, he knows you know.
ToS
The hearing mechanism in the inner ear is as much physics as the air waves.
Your just talking BS & you & every sensible person knows it
ToS
Other way around, I'm afraid - they are pressure waves but who really cares?
You appear not to understand that a sine wave is the description of a function or shape. Sound does not own it!
A point on a spoke (radius) of a rolling wheel describes a sine wave or curve.
If you want to continue to deny Fourier you have a hard task ahead of you.
Your aggressive tone does not help your case.
Merrill,
Er, a lot of people do care Merrill, and as you do not, it indicates a lack of genuine knowledge about a subject that someone like DF96 really does know about. So when he speaks, you should listen.
ToS
(In reply to merrill99)
:cheers: ToS
Merrill,
ToS
Sorry, I was really saying it is/it isn't was getting to be a boring discussion not worth continuing - who cares was my shorthand for this as I suspect many here don't really care
A sine wave is a useful model, that's all - it doesn't describe the reality of what is impinging on the eardrum which is compression & rarefaction of air molecules - sorry but this is physics 101 & pretty boring to keep discussing it
Apologies tos if I seemed to upset your new BFF 😎
Yes, a function is a model of the world, QED
I've never heard a point on a spoke of a rolling wheel - you might have but I would suggest a DBT if you did to prove to me you can hear this😀
Funny how pointing out that a sine wave is a model/function is suddenly turned into denial of Fourier
I think I hear a post coming that I should be getting a noble prize 🙄
Merrill,
You obviously have yet to master the art of deflection - you need to try harder.
ToS
Yes it does, the only difference is it's longitudinal
What you are trying to say is that the compression & rarefaction of air molecules which is sound can be modelled as a longitudinal sine wave when the density distribution of the air molecules are mapped.
Still doesn't mean that sound is a sine wave
sound is usefully modelled by sine waves - sound is not composed of sine waves
Do you get the distinction?
You cannot declare a public discussion as "boring" to your convenience, the only way is to abandon it. Unless your single purpose is to stir the pot.
BTW, what are you doing on this forum? You don't seem to have much fun contributing here, isn't it?
Yes, I can declare it boring when I find it boring & suspect that others do too.
Consider it closed & yes, I'm having fun, aren't you?
And how would you measure that? 🙂 Rather remotely I would hope! But I am quite sure such a field would cause havoc with any audio gizmo.
My RF test chamber is basically a 50 ohm rectangular transmission line of large enough size that I can put the device under test inside it. It is powered by a 2 watt linear amplifier that goes through a 3 dB amplifier protection pad and into a 50 ohm termination. An AM modulated RF signal generator is manually swept over its' range and the audio output signal is monitored.
I actually have some gear I am working on that passes that test. Almost nothing else does so far based on my limited tests.
