Seems to be a different definition of the terms "close-minded" and "open-minded" .........
No debate here, I am pretty sure we are using different definitions.
<snip>
Once you cite the proof I asked way back about that debilitating stress causing listeners to not hear difference in level matched DBT but did hear it when the stress is removed in level matched DBT.
You were/are asking for "proof" for a statement that i´ve never made.
I´ve posted and cited evidence for the different levels of distraction raised by different experimental conditions (i.e. test protocols and even different wording of instructions).
i know i like a rolled off top
That's more than rolled off top. Looks more like disconnected tweeter.Test track played in entirety with averaging....Dayton imm6 mic
Folks, it would be great if you could find a way back to a less hostile/agressive style of communication.
I'd second that. Would be great if some of the ego's were left at the door before entering . . .
Then why did you state "As there exists sufficient evidence (often already cited in other threads) that different test protocols provoke "stress" effects in different ways"You were/are asking for "proof" for a statement that i´ve never made.
"cited evidence" is the real tale here. What you posted was your opinion.I´ve posted and cited evidence for the different levels of distraction raised by different experimental conditions (i.e. test protocols and even different wording of instructions).
All that discredit attempt of double blind test wasn't done by you? Oh, that was jkeny... another one in audio business.
If they aren't, it's simple enough to ignore that aspect and just focus on the salient points? We do it in the real world all the time, it's called survivalI'd second that. Would be great if some of the ego's were left at the door before entering . . .
lol....well that’s what works for me!
And I assure you they are connected....crossed at 2k
It appears that you are in very uncommon category.lol....well that’s what works for me!
Do you mean in relation to stereo?Over the years I've tested the stability of both lateralization as well as localization on myself only. And in that process I've had to do a lot of research.
I hear that often!
I listen louder than I should.....rolled off top is just smoother.
There’s not a whole lot of program material above 10k and I can’t hear much above 16k so....
Of course it is obvious that any toxic compound must damage sound.Max Headroom said:These first three are 'friendly sounding' materials, there are toxic heavy metal compounds used as some colour pigments and I maintain these are not 'friendly sounding' and impart bad signatures.
Now here is an interesting test: find a compound which is toxic to one species but not to another and see how it affects the sound for each species when included in the insulator for a cable. You might not be able to get cats or dogs to do an ABX test, but I'm sure something can be done as their response to sound can sometimes be seen.
Hi everybody! I can't put in a thought here, because you guys are so involved in attacking each other! '-) MMB, you have a problem that will probably return. It might be in your volume control, but it might be elsewhere. It is NOT BREAK-IN. If your set up works for you, then OK. If not, change it. I have a similar set-up but with a much bigger screen and my good speakers (the ones that I seldom use) are too far apart. This is a problem that I would like to resolve, but if I put my Sasha towers closer, they would block the screen. The Met7's are relatively tiny and so fit below the TV screen, and they actually give a more convincing stereo image.
Most of what is debated here has been researched over the decades. It is just not on the internet. Too bad.
Klipsch did it for a while in fact the Cornwall originally was a center speaker for the klipschorns.
Actually, I think it was the Belle Klipsch...
I agree, stereo is old hatMost of what is debated here has been researched over the decades.
Thanks John,
Man....I was hoping it was just a break in thing!
Who should I talk to at parasound? They have yet to return my message I left Thursday last wk......The dealer I bought it from is no longer a authorized parasound dealer, he was when I bought it last yr though.
I really hate to put it in the hands of fedex/ups to go cross country!
Yes I really love reading old articles and audio literature from the 50’s/60’s
John Kloss, Ed Villachur, Winslow Burhoe....all the behind the scenes guys.
Edit...volume control does seem to make sense because it carries the post processed sub out signal...correct? I had a hard time understanding why the sub was also compromised during the ‘event’ and that would explain it...no?
Yes. At first, headphones...I was really having a problem with imaging. Turned out the sound card was sharing a DAC with a pair of S/H. Image was off center, and panning it back to center produced really weird image problems.
That started my getting back to basics, starting with the testing done by the acoustic guys. And when I learned what ITD actually was. I really had difficulty believing that humans can discern at or below 5 uSec, we can't possibly align the speakers that well.
Griesinger has some really good stuff on his website, if anybody is interested.
jn
MMB, do not worry so much. IF your problem occurs again, note what it takes to get it going right again. IF it is pounding on the case, then open the case and look around, as something is probably loose or there is a bad solder joint. Stay away from sending the unit back if and until it really breaks permanently.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
